Anti-spin is NOT an LSD... Right??
Old Mar 24, 2009 | 03:06 PM
cheapbeater's Avatar
cheapbeater
Default Anti-spin is NOT an LSD... Right??
I am planning on changing my diff fluids over to royal purple. I am 99% sure I dont have a limited slip rear because with one tire on ice, and the other on pavement it only spins the one on the ice. If i hold the brakes, it will spin both, and if both have even traction it will spin both... so I am asuming it doesnt have a lsd.
I looked in the glove box and on the sticker it said something like this:
gear ratio: 3.92
rear axle: corporate 9
rear differential: anti spin
So what is an "anti-spin"?? And do I need a friction additive with it?
Also, is the 3.92 a lower/towing gear or is that the standard ratio?
thanks
Old Mar 24, 2009 | 03:22 PM
casper3380's Avatar
casper3380
anti-spin is a lsd, limited slip differential, same thing just a different name.
Old Mar 24, 2009 | 03:32 PM
HammerZ71's Avatar
HammerZ71
Casper is correct, you have a LSD, the reason it doesn't work the way you think it should is that the AAM LSD is just a sorry POS...
Old Mar 24, 2009 | 03:56 PM
cheapbeater
SHET! that is not what i wanted to hear... so do the clips fall out of the AAM lsd too? should i get a trutrac and use this one as a boat anchor?
so how come it only spins one tire on ice?? is it really that big of a pile?
Old Mar 24, 2009 | 04:04 PM
magnethead's Avatar
magnethead
i was told the stock LSD is a torque-activated LSd. meaning it's only an LSD is very specific conditions.
that said, even with 160K miles, you can still hear/feel the tire chatter in turns on our hemi.
Old Mar 24, 2009 | 04:07 PM
HammerZ71's Avatar
HammerZ71
The "Chrysler Corporate" and AAM axles/differentials are one and the same...
Old Mar 24, 2009 | 04:24 PM
cheapbeater
so if the clips fall out, how much damage do they do?
magnet- you said you have 160000 miles on your lsd, have you ever had any problems with it? i never hear mine chatter...
should i wait for this thing to crap out, or change it now?
I wish I hadnt asked if it was an lsd... now Im always going to be worrying about it...
Old Mar 24, 2009 | 06:43 PM
MikeHTally's Avatar
MikeHTally
Wait a minute -- "...one wheel on ice, the other on dry pavement, it spins the wheel on ice..." is a peg-leg. If I put one rear wheel on wet grass (not much ice here in Florida) and the other on dry pavement, the truck goes.
Old Mar 24, 2009 | 06:55 PM
ramracing4.7ltr's Avatar
ramracing4.7ltr
i noticed before i installed my geas that lately when i had turned corners something was not right because i think oh the wheels was hopin! and as i said in last threads about gears , they broke in and clips were broken....i m not exactly sure if they go hand and hand though
Old Mar 24, 2009 | 06:59 PM
magnethead's Avatar
magnethead
It's my dad's truck (i drive the Dako), but we've only had the lube changed...no actual servicing. Like i said, on the loose-surface roads, you can hear the inside wheel chatter-spin like it's locked up with the outer.
