Bahh they rub
Old Mar 25, 2009 | 07:15 PM
shnill's Avatar
shnill
Question Bahh they rub
so i got my truck lifted. now after the tire install (kumho KL71 35/12.50/17) they are rubbing on the control arm when the wheels are straight. The shop is installing 1/4inch wheel spacers -- think that will solve my problem? also what about turning?
Old Mar 25, 2009 | 07:20 PM
red06RAM's Avatar
red06RAM
What kind of lift? What year is your truck? And why pay a shop to install wheel spacers?
Old Mar 25, 2009 | 07:22 PM
Seanutz's Avatar
Seanutz
The 1/4 inch spacers should be fine. I had them on my 91 F150 with 35's and a 3" body lift. The tires rubbed a bit when turning if I remember correctly. I just cut the plastic mud guard thing in the wheel well.
Old Mar 25, 2009 | 07:23 PM
shnill's Avatar
shnill
rough country lift --- 2008 1500 -- umm i couldn't drive it outta there -- so think that will work or what?
Old Mar 25, 2009 | 07:24 PM
shnill's Avatar
shnill
im not worried about the rub on the plastic -- im talking tire killing control arm rub
Old Mar 25, 2009 | 07:27 PM
red06RAM's Avatar
red06RAM
Do you have the stock 17's? Can you take a picture of where it rubs? The spacers should do the trick.
Old Mar 25, 2009 | 07:34 PM
shnill's Avatar
shnill
yeah its the stock 17's - i cant take a pic its at the shop -- umm but if its rubbing on the control arm and then i space it 1/4 inch -- it should never rub through the whole turning radius because that is the axis of the turn, right . like say this thing - the dash is the control arm and < the thing is the wheel -< that is rubbing now add the spacer - < that should never rub assuming that - stay the same during the turning radius , and it does
Old Mar 25, 2009 | 08:43 PM
oefootball_70's Avatar
oefootball_70
yeah I had that prob. I put a 1/4 and it fixed it right up.
Old Mar 25, 2009 | 09:19 PM
HEMI07's Avatar
HEMI07
what size lift did you get from Rough Country? I thought they only made the leveling kit with the rear blocks for the 08
Old Mar 25, 2009 | 09:22 PM
HammerZ71's Avatar
HammerZ71
yep, 1/4" spacers or an aftermarket wheel with some decent backspacing are what you need...
