Speedo not working
Old Mar 26, 2009 | 04:31 PM
Quasar's Avatar
Quasar
Default Speedo not working
Hi, My 2004, 1500 Ram, is coming up with the fault code P0501 Generic VEH Speed Sensor A
Range/Performance
As I live in Scotland UK, It is not easy to get somebody to work on them, has anybody had the same problem and how did they fix it?
Regards
Andy (Quasar)
Old Mar 26, 2009 | 05:17 PM
sos's Avatar
sos
I think it's probably the rear ABS sensor which is mounted on the rear differential. First and cheapest (free) fix is to make sure the connections are tight. There will be a wire coming from the differential, just follow it and make sure it it's not broken or have loose connections. Second, I'd try replacing the sensor itself. It's a relatively inexpensive part. On my old Dakota it was roughly $35 US, and an easy DIY fix.
Old Mar 26, 2009 | 05:34 PM
HammerZ71's Avatar
HammerZ71
The problem is probably a bad VSS on the rear differential. That's the sensor that the ABS reads, and where your speedometer signal comes from.
A dealer only part, but like SOS says it's cheap, retail for a Ram is $39.95 and probably all of a 10 minute swap...
