Cold Air Intakes
Old Mar 31, 2009 | 12:24 PM
  #21
TheFist's Avatar
TheFist
Originally Posted by Got_Hemi44
Its the big plastic box that attaches to the throttle body. It's the black box on top the engine in the picture below that says Hemi 5.7 V8. Basically it's only purpose was to tone down engine noise, but it really restricts the air flow robbing you of HP and MPG. Just one of those comfort over performance things.
Ok, got it now. guess I should have been able to figure that out.
I do alot of driving on real dusty dirt roads. How bad are these open filters for the engine in those situations?
I recently purchased an 07 ram and if it proves to be reliable I'm planning on doing a few mods.
Old Mar 31, 2009 | 01:35 PM
  #22
TRXHemi's Avatar
TRXHemi
I made one myself using PVC and a K&N filter....
Old Mar 31, 2009 | 02:09 PM
  #23
chambers's Avatar
chambers
Originally Posted by 08arhemi
Thanks gents...so it's basically a decision about whether or not I want to keep my hemi hat and kinda do a cold air intake vs. spending a few hundred more and removing the hat and gaining a little more HP. How much HP did you guys get by removing the hat?
Well you can get the spectre from airram.com, autoanything.com, and other sites for about $160. There are even cheaper knockoffs of the AEM/mopar/spectre under names like velocity, bombz, and kool vue for as little as $70. I think autopartswarehouse has the velocity. The one's w/ the mount on the side tend to break off, spectre revised their intake so the mount is on the bottom to fix this. All of the performance gains are really close unless the intake uses a true ram air setup w/ ducting or a ram air hood.
As for filtration and driving in dusty conditions you can get filter wraps that are foam or other materials to help with that. I went with a true flow foam filter for my intake b/c they are pretty much the same as uni filters which dirt bikes and atvs use in very dusty conditions.
Old Mar 31, 2009 | 04:16 PM
  #24
Got_Hemi44's Avatar
Got_Hemi44
Most aftermarket intakes aren't in boxes to maximize air flow. They will still filter out any debris just like a stock filter. If you're not looking into a full out performance intake, but still want the added benefits of after market, I'd suggest a K&N. They are probably the worlds most reputable intake manufacture and have many hours of research into each design.
Average price is about $300, which is little bit in the upper range of intakes, but it's definitely worth it.
Here's one for $293 and free shipping
http://www.lmperformance.com/15417/76.html
http://www.knfilters.com/
Old Mar 31, 2009 | 07:01 PM
  #25
V_Scapes's Avatar
V_Scapes
K and N says around 10-12HP gains around 5300rpm, but when are you going to be running in those rpms unless you drive like an *******. but you can definatly feel the power boost even around 3000rpm. love my 57 series.
Old Mar 31, 2009 | 07:43 PM
  #26
lxman1's Avatar
lxman1
Site Moderator
Just get the Airaid Jr. kit. MIT tube and high flow stock filter replacement.
Same gain as the $300 kit for about 1/2 price.
http://www.autoanything.com/air-inta...0A2643887.aspx
Old Mar 31, 2009 | 07:47 PM
  #27
Got_Hemi44's Avatar
Got_Hemi44
I drive like an ******* thank you very much
And on the track
Old Apr 1, 2009 | 12:35 PM
  #28
TheFist's Avatar
TheFist
Thanks alot guys, appreciate it.
Old Apr 4, 2009 | 07:41 PM
  #29
matthewbeard's Avatar
matthewbeard
you know there was a recall on some of the 57 series. might check it out to see if you have one of the ones recalled
Old Apr 5, 2009 | 12:54 PM
  #30
TheFist's Avatar
TheFist
Anybody use the Bank CAI's?
