Idle Miss...
Old Mar 30, 2009 | 06:59 PM
blackram1500's Avatar
blackram1500
Default Idle Miss...
Almost everytime i stop at a light it starts missing and I have done my plugs and air cleaner, so any ideas of what else?
Should I change the Map or the egr?
I am planning on changing the cables this weekend and was also going to do a Comp..check just to see what the cyl. are running at.
The truck is a 05' 5.7 hemi
( There have been no codes come up )
Old Mar 30, 2009 | 08:23 PM
blackram1500
Also someone said it could be the type of plugs I used..true or false.
I used NGK
Old Mar 30, 2009 | 08:37 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
What did you gap the plugs to? I know you think it's a miss but can you explain exactly what it's doing...could be something else.
Old Mar 30, 2009 | 09:20 PM
ramhunter9's Avatar
ramhunter9
gap could do it without throwing a code . you should have a .45 gap if im not mistakin and you should have used good ol champion copper factory plugs
Old Mar 30, 2009 | 11:41 PM
blackram1500
Unhappy
I guess during idle it lopes every so often...feels like it is in need of a major tune-up.
I am using NJK plugs and did the gap at .45 and torque to 14 ft. lbs
Old Mar 31, 2009 | 12:58 AM
Rebeltilldeath3's Avatar
Rebeltilldeath3
IAC valve
Old Mar 31, 2009 | 01:06 AM
blackram1500
Does the Hemi have a ( IAC VAVLE ? )
Old Mar 31, 2009 | 01:22 AM
Rebeltilldeath3
If it does, that's the problem lol
I'm honestly not 100% sure, these motors are new to me.
Old Mar 31, 2009 | 01:31 AM
blackram1500
Just checked into it and the Hemi doesn't have a IAC Vavle so now we both know...lol
Old Mar 31, 2009 | 08:12 PM
blackram1500
Anyone have any other Ideas...
