seafoam?
Old Mar 31, 2009 | 01:12 PM
pythonbunny's Avatar
pythonbunny
Question seafoam?
I have a 03 1500 with the 5.9 magnum. I just tried to seafoam my truck through the brake booster as directions state. The problem is when i unhook the vac line from the booster my idle only increases a bit, and when i start to let the vacume suck some of the seafoam (very little like a mist) it starts to die. It took maybe 10 minutes to do a 1/8 of the can. I let it soak for 10 minutes off and no smoke or nothing just would not keep running unless i kept the rpms up. After about 5 minutes the idle was back to normal. What did i do wrong? By the way i put a 1/4 of the can in the tank afterwards.
Bryan
Old Mar 31, 2009 | 01:23 PM
ramhunter9's Avatar
ramhunter9
i thaught seafoam was only for your oil and gas????
i used some of that in my old 5.9 and i just pit half a can in the gas tank and half in the oil started her up and i had a good smoke show and it worked like a charm.
never heard of it going threw the brake booster ?
Old Mar 31, 2009 | 01:58 PM
korby05's Avatar
korby05
yeah you can put it through the brake booster...what it does is gets sucked directly into the cylinders and cleans it out...
to do it the best way you need 2 ppl to actually do it..yourself to pour it in and somebody in the truck to hold the rpm up.. we did this a couple times with my old truck and with a buddies of mines car..this stuff does a great job..
Old Mar 31, 2009 | 03:37 PM
mopar6spd's Avatar
mopar6spd
I'd recommend Marvel over seafoam..
Just my opinion..
Old Mar 31, 2009 | 03:49 PM
matthewbeard's Avatar
matthewbeard
It just cleans out the cylinders?
Old Mar 31, 2009 | 03:58 PM
Trigger's Avatar
Trigger
Just my opinion..
Really? Did you have a bad experience with Seafoam?
I've seen heads pulled after using Seafoam. A little light brown around the exhaust valves, but otherwise clean.
I don't know what's in it, but it definately works.
Old Mar 31, 2009 | 04:03 PM
mopar6spd's Avatar
mopar6spd
Well, i'm sure either one is going to do what you need. I just always thought seafoam was more for removing water and whatnot. and marvel was more of a lube/cleaner for the heads/injectors? I may be wrong, but like i said im sure either one will work.
Old Mar 31, 2009 | 04:08 PM
04-fourseven's Avatar
04-fourseven
I didnt know you could do it that way. half and half. But you have to change the oil right afterwards right?
I was told to run around the block before, get the oil hot. Then after dumping it in your system, run it kind of hard for about 5-10 minutes, then change your oil.
Old Mar 31, 2009 | 04:22 PM
Ramdamit98's Avatar
Ramdamit98
Pretty much a two person job with the fly by wire throttle body on the Hemi. With an actual cable throttle on my '98 I could just rev in up myself from under the hood while I used the Mopar Combustion Chamber cleaner, but now with the Hemi I need someone in the cab to keep the rpm's up so it doesn't stall.
Old Mar 31, 2009 | 06:01 PM
Matt99's Avatar
Matt99
Guys, I have heard so much great stuff about seafoam, but recently got a horror story.
Seafoam actually cleans out the cylinder so good that all of the lube is taken out with it. If you do not take it slow and let it idle for awhile (with a good oil) it will actually burn out some of your seals until it gets lube in the cylinder.
Clear this up for me...this all came from a 75y/o mechanic so it might be old school engines or something
