3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Was that terrifying when you just started sanding? ha. I would be freaking out. What kind of paint did YOU use. how many coats of primer, paint. etc?
welll it tookme about an hour and a half per panel to sand it, so i knew i had to do a good job or id be doing it all over again.. but i did at one point ask myself what the f am i doing, ive never done it before. but after i had a little freak out i kept going. The first time i painted it i had a bad reaction, shop was too cold and had bad fish eyes. So i bought a da sander and it sanded it allll back down again. Then i turned the heat up in the shop and did it again. The paint i used is called HOT RODZ BLACK. You can order paint kits from there website which is what i did, or you can go to any autobody shop and ask for a couple quarts of paint topaint ur truck. My truck took 1 coat of 1k primer and 1 coat of sealer, then about 3-4 coats of the black and 3 matte clear coats.
Alright, so now i'm considering painting my bumpers the same color as my truck. Any tips. And where in the world can you find same color paint? I can't find it anywhere.
Hey Twink I remember you said you had put in 5000 into your ram was that in American money or Canadian? I was also wondering what you spent on each of your parts. I know you spent 1000 on paint. Just curious
