Old Aug 10, 2015, 07:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
Tire thump sound when braking
Old Apr 1, 2009 | 07:33 AM
snidehockey's Avatar
snidehockey
Default Tire thump sound when braking
I'm trying to narrow down some weird behavior when I brake...
pretty much the whole cab has always vibrated when I brake anything more than just feathering the pedal. When I come to a hard stop there's thumping that seems to be coming from the front wheels - like the sound when you have a flat. I don't THINK it's warped rotors because I have had that before and it makes the steering wheel go left right left right left right when I would brake - that doesn't happen now, and actually the steering wheel itself seems pretty normal.
My guesses are that either the band(s) in the front tire(s) are broken or there is a rotor problem.
and as far as I know, everything is stock up there.
Old Apr 1, 2009 | 08:41 AM
BEAR's Avatar
BEAR
it's hard for me to figure out a sound without ever having heard it myself but if it were me I would pull the front tires off and take a look. Look at the treads on the tires, the rotors, just look at everything to see if something seems out of the ordinary.Maybe somebody else will hollar at ya with a more exact answer but dats all I got.
Old Apr 1, 2009 | 08:49 AM
HammerZ71's Avatar
HammerZ71
Even thought the symptoms are not the exact same, don't rule out a warped rotor, but it could also be a separated belt in the tire. I cupped tire would also do this. Have you looked the tires over for anything unusual?
Old Apr 1, 2009 | 09:01 AM
snidehockey
would a separated belt affect the ride when not braking? Because it seems to ride very well otherwise.
It has about 55k on it and I got it at 45k so I'm sure doing a brake job on it wouldn't be a bad idea either way.
Old Apr 1, 2009 | 09:53 AM
Rojhan's Avatar
Rojhan
Broken/bent caliper pin? Stuck caliper?
Or, going beyond the brakes; spring/coil mount loose/broken? Other suspension loose/broken?
Old Apr 1, 2009 | 09:58 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
it never knocks any other time other than braking?
rotate your tires and see if the sound moves with them.
Old Apr 1, 2009 | 10:11 AM
Rojhan's Avatar
Rojhan
As an additional thought; how about loose lugnuts/broken lugs?
Old Apr 1, 2009 | 10:12 AM
rtmtrrdr's Avatar
rtmtrrdr
mine has the same thing.My brother works at a mechanic shop and i had it checked out.its definately wraped rotors for me.i wouldn't rule that out
