utility trailer question
If this is posted in the wrong forum, I appoligize. Just trying to figure this out.
I have a utility trailer I have used for a bout 3 years. Works great... well it did, I recently broke a leaf spring. It is a homemade trailer and I cannot replace the spring.... so I ordered a Torflex axle at Red Neck Trailer supply. I got a 2200 pound axle with a 3 inch drop and a 45 degree down arm. Paid about $240 for it. Had to get the drop so it would sit level behind the RAM.
So here is the question. I got 5 on 4 1/2 hubs with extended hubs so I could put a 15 inch wheel on it. Does anyone know if I could use Jeep steel wheels and mount trailer tires with a C load rating on them and be OK?? The guy at the trailer supply store said that I shouldn't run passenger rims on a trailer. I have to think with a 2200 pound axle a jeep steel rim should be strong enough.
I am not trying to be a cheap a$$ but, he quoted me 110 for one rim with a bais ply tire on it or $150 for a radial on it. I have found radial tires for about $80. That would be a huge savings for me.
My 6' x 12' utility trailer has 15" wheels. A local tire store quoted me something like $240 for three tires and a spare wheel!
I bought three used tires and a spare wheel recently for a bit over a c-note. Why not passenger car tires, I wonder. They should do fine. What's the max cap of the trailer, a ton or so?
Much simpler and cheaper. A ball mount with a different drop would probably be about $20-$25. If you change vehicles later, add a lift, etc. the level will be off again, and another ball mount will still be cheaper.
You can also get an adjustable ball mount.
Trending Topics
you have to use trailer tires because they have reinforced stiffer sidewalls to prevent sway and support the load.
trailer rims have to be corrosion free ( galvanized / aluminum ) you may also have problems with clearance for the brakes / sidewalls. will they be strong enough, hard to say without some specs for the rims. will they be legal and safe, no.
