foglights and highbeams on at the same time? (i know its on here somewhere)
Old Apr 13, 2009 | 10:26 AM
flwalks's Avatar
flwalks
Still need to shorten up wires to and from relay
Old Apr 13, 2009 | 10:30 AM
Matt99's Avatar
Matt99
And what is the difference in that and Nittos simple inline trick?
Old Apr 13, 2009 | 10:55 AM
flwalks's Avatar
flwalks
This way you don't load your factory wiring with the load of the high beams and the fog lights. This is about double the amps and would probably not be a problem but I personally would not take the chance of frying the high beam circuit.
Old Apr 13, 2009 | 03:14 PM
Lowlygovemployee's Avatar
Lowlygovemployee
I added the factory dodge fog light kit to my truck (my truck was already pre wired). When I had my service manager friend turn them on, I saw the screen that asked if we wanted the fog lights to stay on with the high beams (mine do). So the dealer can do it for you.
Also, we tried to turn on the daytime running lights, but he didn't have the right program.
Old Apr 13, 2009 | 04:37 PM
oefootball_70's Avatar
oefootball_70
I see the two relays, but where exactly on each relay do I attach it to. Sorry. I am not the best at transferring it from a picture to real life.
Old Oct 14, 2011 | 10:19 PM
Jsmith180601's Avatar
Jsmith180601
Originally Posted by dodgenitto
No The fogs are on with the high beams all the time. I prefer it that way.
does this affect the fog lamps when the turn signal is turned on? also wat gauge wire did u use?
Old Oct 14, 2011 | 10:27 PM
Cthulhu's Avatar
Cthulhu
The control module (TIPM?) does it. My bullydog programmer enabled it. So, yes, the dealer should also beable to do so... whether they will or not, I'm uncertain.
Old Oct 15, 2011 | 05:07 AM
HammerZ71's Avatar
HammerZ71
Yes this is TIPM controlled on '06+ Rams and can be turned on with the Starscan tool. On earlier Rams, can be done by connecting the relays...
Old Oct 15, 2011 | 10:46 AM
HemiLonestar's Avatar
HemiLonestar
A dealer or anyone with the scan tool can enable it in 02-05's, it just has to be set to 'export' in the computer.
Old Oct 15, 2011 | 11:17 AM
zbiggboy's Avatar
zbiggboy
The reason why they don't sell trucks or the dealership won't set up your truck to run with the high beams and the fogs on at the same time; is because it is illegal. DOT sets the standards for all lights. The height of the beams, total wattage ect. In Fact if you are running a 2500, or 3500 a DOT officer can cite you. Trucks at those weights are considered commercial.
James
