Trans Gauge Install Questions
Old Apr 15, 2009 | 01:23 AM
  #21
ramjamhemi's Avatar
ramjamhemi
Originally Posted by RubberFrog
Here are the test port locations-
You want to use the TCC APPLY which is port #3 in the picture. It gets more consistent flow over the sender than port #1 does.
Old Apr 15, 2009 | 01:33 AM
  #22
ramjamhemi's Avatar
ramjamhemi
SilverBullet, where did you get the A pillar pod at, and did it come pre-painted?
Old Apr 15, 2009 | 02:31 AM
  #23
Alpheus's Avatar
Alpheus
I'll bet your local place can get them because they're autometer parts, but they won't be on the shelf.
Thanks for the heads up...
Old Apr 15, 2009 | 08:20 AM
  #24
SilverBullet08's Avatar
SilverBullet08
craigslist and yea already the write color of the interior
Old Apr 15, 2009 | 01:07 PM
  #25
SilverBullet08
hey frog when i use port 3 and put the sender there is alot of tranny fluid gonna come out?
Old Apr 15, 2009 | 01:09 PM
  #26
RubberFrog's Avatar
RubberFrog
A little, do it when the tranny is cold. Thread the sender in to the adapter first. Then pull the plug on the test port and swap it out real quick! You'll only need one paper towel if you're fast!
Old Apr 15, 2009 | 01:12 PM
  #27
SilverBullet08
ok great i havent done anything like this before. i dont want to mess up my tranny lol i still have to get those parts for the sender. you need to do this mod so you can make a video of it haha
Old Apr 15, 2009 | 01:23 PM
  #28
04-fourseven's Avatar
04-fourseven
amen on the vid.
Old May 9, 2009 | 02:19 PM
  #29
SilverBullet08
alright guys im doing this right now. where is a safe place to run the wire? over the tranny and through the firewall? any ideas? thanks
Old May 9, 2009 | 02:24 PM
  #30
HammerZ71's Avatar
HammerZ71
I'm anxious to see how you make out, my pod is installed with the gauge in it, but the sensor and wire is tie wrapped inside for now. I was set to drop the pan and tap a hole, as I was told by 2 performance shops I'd have to do, but have hesitated because my tranny fluid ain't even 10k old and is synthetic, not cheap!!!
My only question is why would a couple of performance places not know about doing it this way?
