help! having problems with 07 ram
Old Apr 15, 2009 | 02:23 PM
chopper29's Avatar
chopper29
Default help! having problems with 07 ram
i have a 2007 dodge ram with 5.7hemi. its got the multi displacement crap on it. anyway when i first start it it shakes and makes some loud knock sound from motor. not a fast nock just every so often. it does this for about 10 min. and when its warmed up doesnt make a sound or shake. idles smooth at that time. the code said cylinder 6 misfire. any ideas. dealers tryn to tell me i need valve job,heads,lifters. they also said they looked at valves and everything looked fine but called chrysler and said i need all that. so its not covered since i have 50,000 miles so would like other opinions. thanks alot.
Old Apr 15, 2009 | 02:38 PM
Matt99's Avatar
Matt99
Did you buy the truck in early 07? I have a truck built 06/11/07 and bought 08/23/07 and it has the lifetime warranty. That should be covered under powertrain huh
Old Apr 15, 2009 | 02:50 PM
chopper29's Avatar
chopper29
not sure ill have to check. im leasing it though so they said 3 year 36000. said absolutely nothing was covered. didnt buy service warranty. didnt think i should have problems in 3 years. at least nothing major
Old Apr 15, 2009 | 02:52 PM
chopper29's Avatar
chopper29
jus have a hard time believing thats the problem
Old Apr 15, 2009 | 03:14 PM
HammerZ71's Avatar
HammerZ71
I read on another forum some time ago (maybe a year or so) that the '06s (first year of MDS) had a pre-detonation problem specifically on cylinder #6, and could be traced back to the use of 87 octane gas on a regular basis. Of course, since the manual states that 89 is recommended, but 87 is ok, I'd say it's a design problem.
Don't know if it applies to you, but you may be able to use that info and do a little research to fight them on it.
Don't know why a leased vehicle would not have a lifetime, so check into that as well.
I've searched the other forums I am on, can't specifically find the thread, but I know I've read it...
Old Apr 15, 2009 | 03:27 PM
chopper29's Avatar
chopper29
thanks hammer. i always used 87. maybe thats it. is there a fix for the problem im having? or do u think damage is done already? il look into warranty but according to dealer there is nothing
Old Apr 15, 2009 | 03:34 PM
HammerZ71's Avatar
HammerZ71
Only a compression test will tell you for sure. In the mean time, I'd start using 89 Octane, at least.
I'm trying to find that thread, but I'm on about 4 other Dodge/Hemi related forums and I don't remember where I read it. Searches for "Cylinder Misfire" is popping hundred plus page hits on the one I was thinking it might be on.
Old Apr 15, 2009 | 04:08 PM
chopper29's Avatar
chopper29
thanks. also i appreciate u lookn. im layed off and a couple thousand to fix what they say is wrong jus isnt gona happen anytime soon.
Old Apr 15, 2009 | 05:26 PM
chopper29's Avatar
chopper29
does anyone know how many psi each cylinder should have in the 5.7hemi. dealer told me my 6 cylinder had 120lbs and 4 cylinder had 150lbs
