Homemade CAI
Old Apr 19, 2009 | 09:24 AM
bigbran's Avatar
bigbran
Default Homemade CAI
Hi all
After reading through all the forums, I am in the process of making my own cold air intake. I am going to post some pics of what I am doing for anyone that is interested. I do have a quick question though... Coming off the air chamber box located at the throttle body there is the AIT sensor and another black rubber tube on the right corner. What is that tube running to and what size is it? It appears to be around 3/8" but I am not sure.
Thanks!
Old Apr 19, 2009 | 10:15 AM
BEAR's Avatar
BEAR
Originally Posted by bigbran
Hi all
Thanks!
Hey bro...I see your new...thats been done here at least a hundred times.If you had of used the search you would have seen that. As far as the rubber tube, I would say PCV??? And by the way... Welcome to DF!!
Old Apr 19, 2009 | 10:23 AM
bigbran's Avatar
bigbran
Sorry...guess I should have posted a little better. Thats what I meant by I had searched the forums. After doing a bunch of research (using the search) I found that alot of people had done their own. That's where I got the idea to try it....figured might as well try a $60 solution first before plopping down $400. I thought it was the PCV line as well but wasnt sure...any idea what size it is?
Thanks for the reply!
Old Apr 19, 2009 | 11:42 AM
Bigc9164's Avatar
Bigc9164
ya u just supper glues it into one of my 90 degree bends. u need it though. haha
Old Apr 19, 2009 | 12:15 PM
SilverBullet08's Avatar
SilverBullet08
which intake is 400?
Old Apr 19, 2009 | 12:43 PM
Redone4x4's Avatar
Redone4x4
are you guys referring to PVC and the rubber reducers that you can get for the TB and airbox ends?
Old Apr 19, 2009 | 12:48 PM
oefootball_70's Avatar
oefootball_70
Get it from O'Rileys. You can get the metal tubing and everything from them too. Still about 60 bucks and it looks professional.
Old Apr 19, 2009 | 02:11 PM
bigbran's Avatar
bigbran
Here is a pic of what I was referring to. I am wondering the size of this line....and where it should be located on the new cai.
Old Apr 19, 2009 | 02:15 PM
Redone4x4's Avatar
Redone4x4
ahh...gotcha now. dont know what size it is, i didnt have to mess with it when i installed mine.
Old Apr 19, 2009 | 03:16 PM
Bigc9164's Avatar
Bigc9164
mine went into the filter box on my 4.7. just drill a 3/8th inch hole and super glue it in. and use a rubber hose for one of your 90 bends and put it in there so it wont rattle and everything. that helps keep mine in tact often!!!!!!!!!
