where could this leak be coming from??
Old Apr 22, 2009 | 11:25 PM
sabedra211's Avatar
sabedra211
Default where could this leak be coming from??
its from under my gas tank by the drive shaft and it smells like gear oil. its from a 2004 dodge ram. thanks!
Old Apr 22, 2009 | 11:44 PM
Alpheus's Avatar
Alpheus
Rear pinion seal maybe? Pull off your diff cover to confirm and throw in some good synthetic while your at it. Check the fluid level in your transfer case also.
Old Apr 23, 2009 | 03:01 AM
abarmby's Avatar
abarmby
Yep.................looks to me like the pinion seal gone.
You know, these 1500 rear ends are crap!
Al.
Old Apr 23, 2009 | 07:53 AM
HammerZ71's Avatar
HammerZ71
Agreed, pinion seal, very common, unfortunately...
Old Apr 23, 2009 | 10:37 PM
sabedra211's Avatar
sabedra211
the rear pinion seal is on the end of driveshaft that hooks up to the differential right? what do i need to replace this just the seal? Also until i can get this fix will anything brake if i continue to use the truck? the diff. still has fluid init. thanks
Old Apr 24, 2009 | 10:43 AM
MontanaRAM's Avatar
MontanaRAM
pinion seal, get it fixed or you'll burn up your rear diff.
Old Apr 24, 2009 | 11:03 AM
Seanutz's Avatar
Seanutz
**** thats where my leak is... how do you change them out?
Old Apr 24, 2009 | 02:38 PM
sabedra211's Avatar
sabedra211
x2 do just take out the driveshaft and put the new seal in???
Old Apr 24, 2009 | 04:45 PM
sabedra211's Avatar
sabedra211
Also how do i find out what size of pinion ring do i get? and is this all i need is the pinion ring? thanks!
