What is the torsion bar crank?
Old Mar 9, 2005 | 07:53 PM
justint420's Avatar
justint420
Default What is the torsion bar crank?
What does it mean to say crank the torsion bars? My dad told me if I do this it will knock the allignment way out of line.
What is this torsion bar crank and what benfits/problems come from it?
Old Mar 9, 2005 | 08:01 PM
GMsucks's Avatar
GMsucks
Default RE: What is the torsion bar crank?
Listen to your father.
Old Mar 11, 2005 | 01:48 AM
sudadog's Avatar
sudadog
Your torsion bars are basically your struts on an independent front suspension. If you get under the front of your truck they will be the two straight bars going from the front "axle" to under the cab. At the back of the bars are adjustment bolts to adjust the stiffness (and height) of the ride. Just remember to adjust both sides exactly the same.
"Cranking" your torsion bars simply means tightening these bolts slightly. Four to five complete revolutions should raise the front end about 3/4". You can go more than that, but it puts a lot of strain on the suspension, makes the ride rougher, plus pust a lot of wear on the outer edge of your tires...
If you stick with a modest 4-5 turns and rotate your tires regularly, you shouldn't notice any extra wear, or much (if any) change in alignment.
