Westin Oval Step Bar - 21-2310
Old Apr 25, 2009 | 11:40 PM
AllanG's Avatar
AllanG
Default Westin Oval Step Bar - 21-2310
Having trouble with the install of these bars. Can anyone give advice on how to remove the body/frame mount bolt?
Old Apr 26, 2009 | 12:18 AM
AF_HEMI's Avatar
AF_HEMI
it should just come right out. whats the problem? If its rusted, spray some PB Blaster up there and let it soak for a little while. Keep in mind, they are HUGE bolts. Its gonna take over 100 lb/ft tq to break them loose most likely (and should be re-tightened as such). If you've got the right size wrench on it, dont be afraid to give it some serious muscle
Old Apr 26, 2009 | 12:55 AM
dedogg's Avatar
dedogg
yeah and watch out i got wet when I took mine out. Not sure exactly what is was, maybe mud i dont know.
Old Apr 26, 2009 | 01:11 AM
AF_HEMI's Avatar
AF_HEMI
only one of my bolts (pass rear) leaked rusty water like a *****. After i put the new one in it squeaked like crazy. save yourself the trouble and either slightly grease the threads or spray wd-40 up there before puttin the new bolt on (or both!). be sure to torque the new bolts down wayyy tight...roughly 100 lb ft, or as hard as you can crank with a normal 1/2" ratchet drive
Old Apr 26, 2009 | 11:06 AM
AllanG's Avatar
AllanG
Thanks for taking the time to reply.
Does anyone know the bolt size, I have tried 3/4 inch, 19 and 17 mm, no luck moving these yet
Old Apr 26, 2009 | 12:35 PM
AF_HEMI's Avatar
AF_HEMI
hmm i cant quite remember. im pretty sure its metric. did you try 18mm?
Old Apr 26, 2009 | 12:49 PM
BEAR's Avatar
BEAR
I'm thinking mine was 11/16's or 18mm. Don't think it was metric tho cuz I ain't got many metric sockets. Find the socket that fits and put all the a** you got behind it or use a cheater bar but it'll come loose.
