Got inspection...did they over inflated my tires?
Old Apr 27, 2009 | 10:33 AM
nemesisprogram's Avatar
nemesisprogram
Default Got inspection...did they over inflated my tires?
I went to Valvoline for an inspection and a week later, I stopped to check my tire pressure and there was 70 psi in each tire. The Max pressure on the side wall says 65psi. Since I got the tires I have been putting 62psi year round. Also, The tires look my fuller in the side walls. What should I do? lower it back? The ride seems fine.
Old Apr 27, 2009 | 11:19 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I would put them at the recommended pressure.
Old Apr 27, 2009 | 11:23 AM
BEAR's Avatar
BEAR
+1 On the recommended pressure. I sure wouldn't go over the max. You also need to allow for the tire heating up during driving cuz the pressure will increase.
Old Apr 27, 2009 | 12:09 PM
Matt99's Avatar
Matt99
well hell I never put over 32psi in my tires...theyre the stock goodies but 70psi? It has to ride like a rock?
Old Apr 27, 2009 | 12:15 PM
abarmby's Avatar
abarmby
Shoot..........I put 40 psi all round and the tyre wear and ride are great.
That's with the 20" chrome clads and Cooper Discoverer HP+ tyres 275x60 R20.
Al.
Old Apr 27, 2009 | 12:21 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
70??? knock it down to 32-40 like they are supposed to be
Old Apr 27, 2009 | 12:31 PM
HammerZ71's Avatar
HammerZ71
Max tire pressure is just that, the maximum. As a rule of thumb, for everyday driving, I have always put 75-80% of the maximum rated pressure in my tires. My current FCII's call for 50 lbs. max and I run them at 40 lbs...
Mike101's Avatar
Mike101
my door sez 60 in the front and 45 in the back for everyday BUT 60 front and 70 back when towing
Old Apr 27, 2009 | 01:18 PM
05hemipwrd's Avatar
05hemipwrd
have you ever checked your gauge, how do you know its accurate? maybe they filled it up to the proper level and your gauge is off....
Old Apr 27, 2009 | 04:28 PM
Got_Hemi44's Avatar
Got_Hemi44
All you guys saying put it at 30-40 do realize he may not have stock tires right?
