Offroad light wiring issues!!
Old Apr 28, 2009 | 12:23 PM
Army_HEMI2WD's Avatar
Army_HEMI2WD
Default Offroad light wiring issues!!
hey guys,
havent been on in a little bit and i have a little problem. I have 4, 6inch offroad lights on the truck (the ones in the sig). They worked fine for a little while and then started acting up i couldn't figure out what the problem was until the yellows died while i was driving. when i got home i had come to find out that the fuse holder had melted. AHHH!! i dont understand why. I used a heavy duty wiring kit for the lights. everything else is fine, except the fuse holders. any suggestions on replacement fuse holders??
thanks
Old Apr 28, 2009 | 01:02 PM
Ridinhigh's Avatar
Ridinhigh
maybe you have a short somewere if it is melting the wiring check that before you replace the fuse otherwise the same thing will probably happen to you
Old Apr 28, 2009 | 11:04 PM
John  M's Avatar
John M
What's the total wattage of your bulbs? Are they all using the same fuse?
Old Apr 28, 2009 | 11:54 PM
Cheeech's Avatar
Cheeech
There are fuse holders and there are china fuse holders. Sounds like you got some cheap azz fuse holders in your kit! I have seen it happens lots of times.
Old Apr 29, 2009 | 06:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yep, you can bump up the wiring and fuse but also check and make sure you have a good clean solid ground. It melted because you were pulling too much amperage through it. I am assuming you are running all 4 lights off one fuse and switch? Did you buy a set of four lights of just a set of two because I wouldnt think all four should be wired to the same switch and fuse.
