Amsoil
Old Mar 10, 2005 | 10:35 PM
cve's Avatar
cve
Default Amsoil
Anyone run with Amsoil oil?
I'm about at the limit when I need to change my oil and I wanted to see if anyone had any thoughts? pros/cons
http://www.amsoil.com/
Old Mar 11, 2005 | 02:08 AM
ross944's Avatar
ross944
Default RE: Amsoil
Go full synthetic, you'll thank yourself for it and you wont have to worry bout it for another 8000-10000 miles. top of the line synthetic is supposed to be good for 15000 miles. im not familiar with amsoil but from what im reading they sound pretty good. mobil1 seems to be the premeire brand for oil. try out this link, plenty of guys there who could help you out.
http://themotoroilsite.com/forums/
Old Mar 11, 2005 | 10:50 AM
moparturd's Avatar
moparturd
Default RE: Amsoil
MObil, I noticed, is now claiming the 15K change intervals. Maybe this isn't new for Mobil 1, or perhaps they changed the formula to match Amsoils most recent offering.
Old Mar 11, 2005 | 12:52 PM
GMsucks's Avatar
GMsucks
Default RE: Amsoil
ORIGINAL: cve
Yep.
Old Mar 11, 2005 | 01:32 PM
horatio102's Avatar
horatio102
Default RE: Amsoil
Mobil1 is the premier brand because it's on every shelf in every store. Amsoil is most likely better stuff though. I run regular oil in my truck and it's got 80k or so without a hint of consumption. I run synthetic in my VW because it's got a turbo that I like to heat up, a lot. I just don't see the cost benefit of running synthetic over regular oil in something low tech, like the Dodge. Sure, the oil can last up to 15k miles, but do you not still have to replace the filter? Oil serves several purposes - to cool, to lubricate, and to clean the engine. It removes contaminants to a safe place - the filter. Just because the oil can lubricate longer doesn't mean the filter can go longer without becoming more and more clogged with crap.
Perhaps I'll switch to synthetic if and when I build a shortblock stroker, but honestly I don't know that I'll have the truck long enough to see any payback for using more expensive oil.
Old Mar 11, 2005 | 01:55 PM
HoosierHemi's Avatar
HoosierHemi
Default RE: Amsoil
When did you switch to synthetic? My understanding is that you need a certain break -in period using dino oil before switching to synthetic. Any help here would be greatly appreciated.
Mike
Old Mar 11, 2005 | 04:09 PM
moparturd's Avatar
moparturd
Default RE: Amsoil
First oil change at 3K on mine.
Old Mar 11, 2005 | 06:04 PM
ViperGTS's Avatar
ViperGTS
Default RE: Amsoil
When Amsoil was a DF vendor, they had a chart that compared their oil to others. Amsoil was supreme. Go for it [sm=smiley20.gif]
-Matt-
Old Mar 11, 2005 | 06:20 PM
moparturd's Avatar
moparturd
Default RE: Amsoil
According to their numbers. I've always wondered at what point it became overkill though. It is possible to over-design something. And considering the price of the Amsoil.??????
Old Mar 11, 2005 | 08:26 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: Amsoil
If you have more than 15k miles on your engine, its ok to run amsoil. If not--wait. The synthetics are so good, that if the engine isn't broke in ie: good compression, they never will while you are running it. I ran it some years ago in a cherokee i had and it ran great.
At that time they recommended running it 6k miles with a filter change at 3k miles, plus the 1/2 quart to make up the difference.
As far as wear factor goes, it is ranked with royal purple, red line etc... a very good oil indeed. and if your dealer isn;t gouging you, it really doesn't cost anymore than regular oil based on the change frequency and cost / qt.
The down side is this---if your motor isn't tight--it leaks oil--at seals, gaskets or whatever, the leaks will get a lot worse.
Repair all oil leaks prior to changing!!!!! otherwise DON'T EVEN THINK ABOUT IT!
