clutch fan help !!! stealership i think is screwing me
Old May 8, 2009 | 06:06 PM
Alpheus's Avatar
Alpheus
Do a search there is alot of info and pics available...
Old May 8, 2009 | 09:26 PM
604's Avatar
604
has anyone made there own fan kit from a taurs? i assume the wiring is all the same for wiring it up right?
Old May 8, 2009 | 09:53 PM
lxman1's Avatar
lxman1
Site Moderator
Get one from a Mark VIII. It fits the radiator better.
Old May 8, 2009 | 10:29 PM
Alpheus's Avatar
Alpheus
Not on an 03...
I say again use the SEARCH function. Every question you have about your e-fan install is in there...
Old May 9, 2009 | 12:13 PM
BEAR's Avatar
BEAR
http://moesperformance.com/index.php...products_id=15
this is the fan I was talking about. Comes with everything you need. Says 306.95 on the page but when you put it in your cart the price drops to 249.99 shipped.
Old May 27, 2010 | 01:29 PM
dodgequad05's Avatar
dodgequad05
Originally Posted by Pyro
The only pain getting the clutch fan off is keeping it from turning...cut a piece of 2x4, wedge it in there to keep the fan from spinning when you turn the bolt.
Where would you wedge the 2x4, how big of a piece were you using?
Old May 27, 2010 | 01:41 PM
cwboyjohnny24's Avatar
cwboyjohnny24
I haven't done the efan mod yet but I'm picturing a 2x4 under one of the blades on the passenger side run from the bottom of the blade to the ground. I may be wrong but that's what I'm picturing. It'll keep the fan from spinning while you're taking the bolts off.
Old May 27, 2010 | 02:46 PM
disturbedgator's Avatar
disturbedgator
i put in a efan from a sable, was quited easy and the thing total cost me around 40$
