Trailer lt.Problem
Old May 8, 2009 | 12:02 PM
Cumminman's Avatar
Cumminman
Default Trailer lt.Problem
Gentlemen,I have lost LH turn and brake lt's on my trailer 7 pin connection,i have traced yellow wire to front of truck and all fuses are good any ideas what to check next?Thanks,Vann
Old May 8, 2009 | 10:26 PM
John  M's Avatar
John M
My guess is that you've lost either fuse #46 (15 amp) or the actual left turn relay itself. This is from a 2003 manual; I don't know when/if it changed for other years.
Old May 8, 2009 | 10:57 PM
Cumminman's Avatar
Cumminman
John where are the relays located?Are they built into the module?I think theres a difference between 03 and 06.Thank you Sir for any help. Vann
Old May 9, 2009 | 01:13 PM
John  M's Avatar
John M
The relays are located in the underhood fuse box, aka the Integrated Power Module.
Hopefully someone with a newer manual will be able to help you.
Old May 9, 2009 | 06:30 PM
Cumminman's Avatar
Cumminman
Bought a tail lt converter and hooked up on the lh brake/turn,$18.00 works like a charm.
