Air Sensor
Old May 8, 2009 | 11:45 PM
KingLui's Avatar
KingLui
Question Air Sensor
where is the air sensor located at for the air intake? i thinks thats what its called, o yeah im goint to remove my air box to install the cold air intake,
i thinks its called the mass air flow sensor.
Do i need to disconnect my battery to reset the ecm?
Old May 8, 2009 | 11:55 PM
Alpheus's Avatar
Alpheus
No Mass air flow sensor its an air temp sensor. Its the only wires that are on your intake. Be careful when removing and installing it because its a bit brittle...
Old May 9, 2009 | 12:11 AM
KingLui's Avatar
KingLui
i dont see any wires or anything on the stock intake! or am i blind?
Old May 9, 2009 | 12:13 AM
SilverBullet08's Avatar
SilverBullet08
its on the hemi hat
Old May 9, 2009 | 12:14 AM
KingLui's Avatar
KingLui
Question
ok im a noob so wheres the hemi hat?
Old May 9, 2009 | 12:20 AM
Redone4x4's Avatar
Redone4x4
in the middle, towards the back of the engine. says hemi on it. just on the front side of that is the plug. its small, only 2 wires and like previously stated be kinda careful with it.
Old May 9, 2009 | 12:21 AM
SilverBullet08
that big thing in the engine bay that says HEMI 5.7...
http://www.trucktrend.com/roadtests/.../photo_01.html
KingLui's Avatar
KingLui
ok and thats connected to the stock intake?
Old May 9, 2009 | 12:27 AM
KingLui's Avatar
KingLui
Question
all i did was take the old one out and put the new one in i didnt see no cables nor conectors or maybe im blind, also why did i have to disconnect tha battery? what happens if you dont?
lxman1's Avatar
lxman1
Site Moderator
Blue wires just to the right of the front hold down bolt under the 5.7
