Help on code(cam/crank position sen.)
Old May 9, 2009 | 11:02 AM
ice-burg-slimm's Avatar
ice-burg-slimm
Default Help on code(cam/crank position sen.)
I was getting the code on both sensors on my 03 ram,the truck had stopped running because of them.I changed the sensors out and the chech engine light whent away,but the truck still wont run.If you fire it up it seems like it's having a hard time staying at idle,it sounds like not all cylinders are firing. Help please.
Old May 9, 2009 | 12:01 PM
Riccs22's Avatar
Riccs22
what were the codes
Old May 9, 2009 | 01:38 PM
ice-burg-slimm
Can't remember the actual code number,but it was for the cam/crank position sensor.
Old May 10, 2009 | 12:00 PM
ice-burg-slimm
can any one help?
Old May 10, 2009 | 12:29 PM
lxman1's Avatar
lxman1
Site Moderator
Try unhooking the battery for about 1/2hr to reset the PCM?
Old May 10, 2009 | 02:13 PM
ice-burg-slimm
That didn't work it sounds as if it's missing.
Old May 11, 2009 | 09:02 PM
ice-burg-slimm
Is there any more suggestions?
