metallic clicking noises at high rpm's
Old May 9, 2009 | 05:06 PM
Nathiest's Avatar
Nathiest
Default metallic clicking noises at high rpm's
2004 Dodge Ram 5.7 Hemi V8
Only just yesterday afternoon getting up on the highway right at about 6000rpms I hear a rapid metallic clicking noise coming from the engine. I only hear it at high rpms and so far there is no noticeable performance lost.
Note the noise went away after being on the road for more then 30 minutes.
Old May 9, 2009 | 05:17 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
6000rpms...I take it you have a tune? Can you datalog to see if you have any knock? The noise could be anything from knock to a loose heat shield...mine makes a clicking noise all the time if it makes you feel any better.
Old May 9, 2009 | 06:05 PM
Nathiest's Avatar
Nathiest
Yeah really I just wanna feel better so thank you.
Old May 10, 2009 | 12:01 AM
lxman1's Avatar
lxman1
Site Moderator
Sounds like a detonation issue. This will burn holes in the pistons if you continue to do so!!
Old May 10, 2009 | 12:11 AM
Redone4x4's Avatar
Redone4x4
this is true, it happened to me....if thats what is in fact making the noise get it taken care of quickly. run higher octane right away, see if it helps.
