removing oem receiver hitch 2005 1500QC
Old May 10, 2009 | 12:49 PM
Terez's Avatar
Terez
Default removing oem receiver hitch 2005 1500QC
Do I really have to loosen/lift the box to remove my oem receiver hitch?
Is it welded or secured also or will it come out when the box is lifted?
I want to remove my oem receiver hitch cause it bent down and over when the truck jacknifed a trailer backing up.
Seems like a pretty flimsy design.
I am going to replace it with a aftermarket hitch that incorporates the hitch box into the cross bar, seems like a stronger design?
Unlike the oem style where the hitch box is weled under neath the crossbar. I don't mind seeing the crossbar under the bumper, in fact I think it looks better too.
Old May 10, 2009 | 03:51 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
It should just unbolt from the frame...if anything has to come off it might be the bumper for clearance but I doubt it.
Old May 10, 2009 | 04:15 PM
Got_Hemi44's Avatar
Got_Hemi44
I have an 06 but i'm pretty sure they're the same. Yes you have to lift the bed off 5-6 inches in order to remove it. The idiots at dodge designed it so the back of the bed covers the area it needs to slide out. Mine had 6 main bolts holding it on. 4 in the back, 2 closer to the cab. You also have to unbolt the gas hose housing from the bed and a little cord by the drivers side door. If you slide under the rear, you should be able to see the 4 big bolts going through the tow package and frame. I'd suggest unbolting those 4 before lifting the bed. Once tow package is unbolted and bed lifted. the whole thing (including rear bumper) slide out. All in all it's a pain in the a$$. Specialy if you have 1 or 2 bed bolts that don't want to come out.
I don't know how you can get a stronger aftermarket hitch than the oem one without custom fabrication. It incorporates into the frame, has 4 big bolts, and also has the bed to hold it on.
Here's some pics from when i removed mine
Bed lifted
Rear end off. On the end of the right frame rail you can kinda see the U notch where the tow package bar slid out from.
Old May 10, 2009 | 05:34 PM
Terez's Avatar
Terez
Default hitch removal
Thanks for the detailed reply Bud! excellent.
This is what I figured would be the case.
Fawkin' brilliant setup!!
After crawlin under there this aft it looks like the oem bumper is also attatched to the receiver and not the frame?
Can I reattatch the oem bumper with the receiver hitch gone?
Are there different rear bumpers depending on whether the factory receiver hitch is used or not?
When you say there is a cord up front is it a wiring harness?
I assume the box bolts are threaded into welded on nuts on the box?
You can unscrew the box bolts completely and the nuts will stay in place on the box?
Thanks for the help.
PS Did you go to a roll pan? How did you like that?
Did you replace the receiver hitch with a roll pan model?
Old May 10, 2009 | 09:14 PM
SeVeReDiStOrTiOn
jesus all for a hitch...amazing
Old May 10, 2009 | 10:01 PM
Got_Hemi44's Avatar
Got_Hemi44
Originally Posted by Terez
After crawlin under there this aft it looks like the oem bumper is also attatched to the receiver and not the frame? Can I reattatch the oem bumper with the receiver hitch gone?
Yea the whole rear chrome bumper is attached to the tow package. As for how to put it on without the tow package, i honestly don't know. I installed a roll pan so once the whole setup was off i just put it in the barn. I'm sure there has to be a way for it to go back on because not all truck have the tow package.
I have an 06, so I'm basing everything off my truck, but I'm pretty sure you would have one too. It's not an electrical cord. It's a small metal cord that goes from the bed to the cab (i think) on the passenger side. I can snap a pic tomorrow for you.
Yes. There is a total of 10 bolts. 4 horizontal going through the frame to hold on the tow package, then 6 vertical going through the frame and up into the box. You don't have to worry about the nuts, they are part of the box
PS Did you go to a roll pan? How did you like that? Did you replace the receiver hitch with a roll pan model?
Yep i got a EFX steel roll pan and i love it. I'm going for more of a street look. I never tow or haul anything so i didn't purchase the hidden hitch with it. In the pictures you can see the square cut out where you can insert a ball hitch. The only problem with a roll pan/hidden hitch is that i'm 99% sure you have to relocate the spare tire somewhere else. The back of my roll pan is about 2 inches from the tire. I still have to get it painted red though
If you have any other questions, just ask.
Ryan
Old May 11, 2009 | 12:38 AM
lxman1's Avatar
lxman1
Site Moderator
The wire sounds like a ground strap for the tail lights from frame to bed.
Old May 11, 2009 | 05:48 PM
Terez's Avatar
Terez
Default removing oem hitch
What a damn PITA !
Has anyone had experience with reattatching the oem bumper after removing the oem hitch?
Am I going to have to buy all the oem brackets and crap to attatch the oem bumper without the hitch?? Prolly?
Maybe an aftermarket rear bumper and hicth is in order?
The oem bumper is starting to rust anyway.
A black bumper and new hitch would be good.
Anyone go this route?
Surely all the holes are present in the rear frame horns to accomodate any aftermarket no drill hitch?
How could they have made soemthing so simple so damn complicated????
Old May 11, 2009 | 07:35 PM
Got_Hemi44's Avatar
Got_Hemi44
It's simple business. You design a product in which only your company/associates can work on, you continue to gain money after the product was first sold. Everything from computers to automobiles are built with this theory. Some companys even reject designs because the average person would be able to fix it if ever broken. I'm going to Ohio University next year for mechanical engineering and I'll probably have ideas shot down because they make to much sense. Go figure
