Might be F@$#!!!!! smoke and oil issues.
Old May 10, 2009 | 11:19 PM
Brett823's Avatar
Brett823
Default Might be F@$#!!!!! smoke and oil issues.
still burning oil. its been doing this for awhile now with really no side affects except less oil on the dip stick. but today upon start up i got a big cloud of smoke out the back and ran ****ty for about 10-15 secs and then it started to run fine. took it on short easy drive and seemed fine. any thoughts on this??
Old May 11, 2009 | 12:10 AM
lxman1's Avatar
lxman1
Site Moderator
Quit trying to bypass the language filter in the thread title for one!!
Sounds like you have a valve seal/valve guide problem.
You might check the PCV valve as well.
Old May 11, 2009 | 12:14 AM
Brett823's Avatar
Brett823
i typed it like that buddy. PVC is not it.
Old May 11, 2009 | 06:52 PM
Brett823's Avatar
Brett823
no ideas anyone???
Old May 11, 2009 | 08:10 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
What color smoke? Probably valve seals like lxman said..
Old May 11, 2009 | 08:58 PM
BEAR's Avatar
BEAR
yep I got to agree with you BUDDY. It definatly ain't PVC unless you got one of those drain pipe intakes. If not then mabe PCV BUDDY. If not then you got valve seal problems and/or a sh** load of blowby.
