egr problem, maybe mds?
Old May 11, 2009 | 10:17 PM
jumbonas's Avatar
jumbonas
Default egr problem, maybe mds?
Hi everyone. I am a new poster but i have been visiting this forum for months since I picked up my 06 QC 5.7. I have exhaustively searched the forum and I think i may have found my answer but I am not certain.
background 34k miles, k&n 1533, m1 5-20
when i cruise from just about 1400-2100 rpm i get a laboring and somewhat clunky sound from the engine, like it needs more throttle, and then if i lift off of the gas, I get a somewhat of a "backfire" sound, but almost like a sneeze or rush of air "dzoooo" if i where to phonetically spell it to have you hear it in your head. even if i keep constant throttle it will sometimes do this. if i give it some juice it is back to normal.
if i watch the tachometer, i see about a 50-100rpm sudden drop when it "sneezes and acts like normal again. I don't know if this constitutes a ping, but any help is greatly appreciated.
Thanks a lot,
Old May 11, 2009 | 11:05 PM
SMKNRAM's Avatar
SMKNRAM
try running with overdrive off it sounds like the overdrive at to low a speed, you are probably around 40-45 mph when it does it and it wont at 55 or higher
Old May 12, 2009 | 11:15 AM
jumbonas's Avatar
jumbonas
still made the noise- OD off under 35 and OD on at 75
Old May 12, 2009 | 05:23 PM
jumbonas's Avatar
jumbonas
any other ideas?
Old May 12, 2009 | 05:41 PM
Gone Fishin's Avatar
Gone Fishin
Take your truck to Autozone and get it scanned for any P-codes. If there is anything wrong, a code will "usually" be thrown, and it will help zero in on what may be causing the problem
Old May 12, 2009 | 05:54 PM
Dodgeboy77's Avatar
Dodgeboy77
mds is cutting in. the sound will change and the rpm goes up a bit while in 4 cyl mode. if you step on the gas it goes to 8 cyl.
Old May 12, 2009 | 08:53 PM
jumbonas's Avatar
jumbonas
Ok so i took some (admittadely bad) videos here they are, #1 occurs around the 14 second mark and #2 around 45 seconds
http://www.youtube.com/watch?v=u2YL95Mx34k
http://www.youtube.com/watch?v=1p-t9ieYn9c
Thanks
Old May 13, 2009 | 06:26 PM
jumbonas's Avatar
jumbonas
I went to advance auto and they said with no cel they couldnt pull any codes, i did the ignition cycle and only "done" came up, no codes. this is getting very frustrating ...
Old May 13, 2009 | 06:36 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like the MDS kicking in and out. Hard to tell, you don't keep the throttle steady.
