4x4 Vibration
Old Jan 31, 2011 | 01:16 AM
  #31
LCanon's Avatar
LCanon
Default 4wd problem
I am in need of help as well with my 4wd. I have a 04 ram 1500 and when I try to lock in my 4wd the shifter flows back and forth with ease and doesnt lock in 4wd. I crawled under the truck and found the shifter, it has a ?linkage rod? that goes to a ? rubber ring on a bracket into the transfer case. where can I find this rubber ring at online?
Old Jan 31, 2011 | 08:11 AM
  #32
Lecrict's Avatar
Lecrict
Cool It's not JUST Chrysler
Originally Posted by silentwarrior
TXJ This is the last dodge I will ever buy, you get no service after you sign the papers when you buy a dodge you are just a pain in the *** to them if you have a problem.!
This lack of service is NOT just Dodge, or a specific dealership. I find it more and more prevalent, no matter what car company, or dealership. It's Transparent support. They will just blow smoke up ur ****, to get ya to buy, and then make excuses, why they can't help ya, after.
NONE of these car companies stand behind their product.
Old Dec 31, 2011 | 10:57 AM
  #33
silentwarrior's Avatar
silentwarrior
UPDATE, Truck had been into the shop for shudder/vibration/noise in the front end. They have told me nothing was wrong every time. Warranty just expired in september, Now that the TRUCK is 3 y/o and has 31k on it they tell me I have a bad left front axle and a bed right front wheel bearing! I have paper work stating my problems and them saying " un able to duplicate" I will be calling DODGE on monday and if that does not work I am taking legal action!
Old Jan 5, 2012 | 10:17 PM
  #34
IowaHemi1's Avatar
IowaHemi1
I took my 2 1/2" lift off my truck and my vibration went away. What ever happened to making a 4x4 level. They do it on the 3/4 ton 4x4 trucks and the older ones. Is there a reason for a 4x4 truck to sit like a car with back end higher? They need to let me design a truck for them! lol
Old Jan 5, 2012 | 11:09 PM
  #35
PRADO's Avatar
PRADO
So this doesnt happen to the 02-05 the right? i havent had a chance to try mine out yet. so i can use the 4hi on any surface right to about 55mph?
Old Jan 6, 2012 | 12:46 PM
  #36
silentwarrior
Dodge said they will pick up the cost of repair minus $100.00 deductible/ If it is out of warranty how do I have a deductible? I am glad I have all of my paper work saved from each trip and how technician writes ( unable to duplicate problem ) two mile test drive then recommends a front end alignment! We will see how it works after the repair!
Old Jan 8, 2012 | 09:16 PM
  #37
IowaHemi1's Avatar
IowaHemi1
I have a $50 deductible on my extended warranty. If they can get it fixed, i would pay the $100. Even though they should have done it before out of warranty. My lower right strut bolt won't come off. They have to replace lower control arm and my bad strut $700 bucks with labor. Those front end parts are spendy!
Old Feb 1, 2012 | 10:33 AM
  #38
XLSLC's Avatar
XLSLC
Default Thanks
Thanks everyone for the great info. I recently crashed my 06 1500 SLT and after the shop did $12,000 worth of work to it I noticed this 4x4 shudder. Sent it back, and just like everyone else, the shop said they found nothing wrong.
Looks like I'll pick my battle with the dealership rather than my repair shop... you all saved me a lot of huffing and puffing with the wrong people!
Old Feb 2, 2012 | 09:09 PM
  #39
silentwarrior
Left front axel right front wheel bearing replaced and a front end alignment., Paid $100.00 deductible. The vibration is not as bad, but still noticeable, I have been unable test if the 4x4 even works because we have had 60 degree weather. I will let you all know how the system works when we have snow. I think it needs both wheel bearing and axel replaced!
Old Feb 3, 2012 | 07:39 PM
  #40
Carnage68's Avatar
Carnage68
My Ram has the Bilstein leveling shocks, and have never had a shudder or vibration while in 4wd or 2wd. In fact the only problem i've had with this truck is an EGR valve go bad on me, but that is to be expected regular maintenace over a long period of time.
