just happen
Old May 13, 2009 | 10:04 AM
Black_Beautiful's Avatar
Black_Beautiful
Default just happen
OK for some reason my truck overheats when it just sits in a parking lot but not when im driving it. It just started to do this when i put the new intake on. Anyone have a clue?
Old May 13, 2009 | 10:15 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
low coolant?
AF_HEMI's Avatar
AF_HEMI
whens the last time you did a coolant flush? looks like its time for an e-fan
Old May 13, 2009 | 10:20 AM
Black_Beautiful
Iv never done one to this since iv got it. if it's runing down the street or what not it's fine. this is the second time iv been sittin somewhere on my laptop and all of a sudden check gauges comes on and im overheating. I just turned it off and it's all most down to the normal temp spot.
Old May 13, 2009 | 10:26 AM
AF_HEMI's Avatar
AF_HEMI
def time for a coolant flush. i think you'll find your coolant is probably very very dark, with some rust in there possibly
Old May 13, 2009 | 01:27 PM
NYBowbender's Avatar
NYBowbender
Sounds like an airflow problem to me... you overheat when you're sitting because you don't have adequate air moving through the rad to cool things. When you're moving you have all the airflow you need.
Old May 13, 2009 | 02:34 PM
snidehockey's Avatar
snidehockey
sounds like the fan's not doing it's job. Or doing anything for that matter.
Old May 13, 2009 | 02:47 PM
Black_Beautiful
So is my engine really overheating or does it just think it is.. As soon as i start to drive or rev my engine the temp goes right back to normal.
Old May 13, 2009 | 02:49 PM
truckin151's Avatar
truckin151
Sounds like the fans gone... If the fluid was bad it would be over heating at all times not just when sitting still...
Old May 13, 2009 | 02:55 PM
04-fourseven's Avatar
04-fourseven
I was going to say you need a flush. It could be so gunked that when your driving it is barely getting cool enough.
But check your fan. All these suggestions are good ones.
