Headunit/speaker problems! Please help!!!!!
Old May 17, 2009 | 11:16 AM
itsa1500's Avatar
itsa1500
Default Headunit/speaker problems! Please help!!!!!
Whats up guys.. anyways a buddy of mine has an 02 ram 1500.. needless to say he had an older model headunit that took a sh**.. So since i had an extra alpine headunit i was like sure he could have it.. so yesterday i took out his old headunit and installed the alpine.. we powered it up and only the front drivers door speaker was working.. i have no idea what is wrong.. i took the headunit out to see if i mixed up any wires and all of them are correct.. i dont know what to do anymore and at this point it is very frustrating.. any help would be amazing.. thanks.. p.s we are using a wiring harness so it just makes everything that much worse.. lol..
Old May 17, 2009 | 11:24 AM
nim81's Avatar
nim81
if it has the infinity factory amp then good luck, you would be better off to run all new wires to the speakers, thats what i did. it only took about 2 hours to wire the four doors
Old May 17, 2009 | 11:28 AM
itsa1500's Avatar
itsa1500
he actually doesnt have the infinity amp.. and he recently replaced the stock speakers.. so would that be the quickest easiest fix?
Old May 17, 2009 | 11:43 AM
Gone Fishin's Avatar
Gone Fishin
Just a thought, did you tap into the pre-amp out lines from the wire harness on the radio instead of the rears??
I wired into my existing 4 spkr system w/ a pioneer harness and it worked without a hitch.
Old May 17, 2009 | 12:12 PM
itsa1500's Avatar
itsa1500
yea bro.. everything is wired perfect to the T.. i have no idea whatelse to do.. btw he is running to 10 mtx speakers but thats on a different mtx amp so its only the remote and the rca jacks so thats not a problem.. and i even disconnected the amp and subs just in case. but nothing..
Old May 17, 2009 | 12:20 PM
Hyazakite's Avatar
Hyazakite
Before tearing more of your hair out, unhook the speaker wires and test each one with an external speaker of some kind and make sure the Alpine outputs are working on the other three channels. This will save you a little time in your troubleshooting.
Old May 18, 2009 | 11:32 AM
bigpappaholt's Avatar
bigpappaholt
I have infinity and i just bought a wire harness from best buy and all 7 of my speakers work and they sound much better than stock headuint.
... I would check door speaker connections, also i would check the headunit and make sure the speaker setting is not just faded to front speakers only. good luck.
Old May 18, 2009 | 12:19 PM
snidehockey's Avatar
snidehockey
yeah like a previous poster said...definitely. Hook that one working speaker to the other 3 not working outputs from the alpine and see if there's sound.
If yes, bad wiring - run new wire
If no, bad output from head unit / setting on head unit
audio is usually pretty easy to narrow down.
