Rhino Line vs Cammo Skinz
Old May 18, 2009 | 12:52 PM
elks's Avatar
elks
Default Rhino Line vs Cammo Skinz
So I have a white 06 mega cab. I spend a decent amount of time on gravel roads. A semi common practice around here is to Rhino Line the wheel wells and the bottom 1/6 of the truck up to the factory line.
I tend to like the look of the black on white... What do you think rhino line the bottom 1/6 of truck?
Another Option are the cammo skins. I hunt a lot and end up with many small scratches from brush etc. I was thinking about using the cammo skins and doing a snow cammo pattern. Realize thath te majority of time spent in my truck will be for doing out door/off pavement driving. About 60% on dirt and 40% on pavement.
Thanks for input...
Old May 18, 2009 | 02:29 PM
SMKNRAM's Avatar
SMKNRAM
I like both ideas! If you do that much off rd the rhino will hold up better than the skins. but the skins would look cool too so r u looking for function or fashion? your call dude~!
Old May 18, 2009 | 02:58 PM
Got_Hemi44's Avatar
Got_Hemi44
I like both ideas too. Rhino liner would hold up better, but camo skins would look better. My friends dad is a camo skins rep and his truck is decked out with it.
Old May 18, 2009 | 03:04 PM
elks's Avatar
elks
Well now I am thinking both.... Going with black rhino line on lower areas then going up sides with a mothwing snow pattern. That would cover most of truck, if not all. Good news is If I do not like it off it comes...
Old May 18, 2009 | 04:31 PM
dirtydog's Avatar
dirtydog
Moderate User
I would get wheel well inserts for the rear. That will eliminate slung rocks and most noises. You could have the liners Rhino coated as well because they are a grayish more than a black. That's what i plan to do. I would get fender flares and just Rhino the lower part. i wouldn't stick anything on your truck. Inner liners for the rear and flares on all 4 will stop most debris from crawling down your paint. As far as brush...well...stay away or deal with fine scratches.
Old May 18, 2009 | 05:15 PM
sos's Avatar
sos
I know you said you like the black on white, but you could also get white Rhino and it would blend in more. Not sure about keeping it clean though.
Old May 18, 2009 | 05:32 PM
chambers's Avatar
chambers
I had line-x do the rockers on my truck and I really like it. Here are a couple pics
