Power Wire
Old May 22, 2009 | 11:03 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
he's right about a resistor working in either direction and a VOM doesn't put out voltage when reading anything. Just go make yourself one and save the money. Now if you just really want to buy a Power Wire I will sell you one I have.
Old May 22, 2009 | 11:48 PM
Dodgeboy77's Avatar
Dodgeboy77
i posted the wrong link, i can't find the spot that airram explains how it works. i have an edge programmer but doesn't this work with the programmer?
Old May 23, 2009 | 02:24 AM
Alpheus's Avatar
Alpheus
Originally Posted by lxman1
Do it right and get a dag on tuner. My Predator does more than any resistor can do.
You ain't gonna get 20 RWHP from a resistor.
A resistor works in either direction, so you can't mess it up. A diode only flows in one direction.
Not a zener diode...
Old May 23, 2009 | 02:28 AM
Alpheus's Avatar
Alpheus
A VOM does put out a calibrated voltage when set in the OHMS function...
Old May 23, 2009 | 10:15 PM
Dodgeboy77's Avatar
Dodgeboy77
yes, i know. If i could find that article by airram, he explains that a resistor can't compensate like the power wire does.
Old May 23, 2009 | 10:44 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
He's full of it...the resistor mod has been done on various vehicles since port injection was introduced and that's all the power wire is. Different value resistors adjust the IAT's signal in different ways...that's why they're telling you to use a 4.7k.
Old May 23, 2009 | 11:31 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
the resistor/powerwire is not doing the compensating, the ECM is. It thinks the air is a bit cooler then it is, so it compensates for what the temp is. now if the temperature outside gets hotter, the ECM picks up a hotter temperature and adjusts.
Old May 23, 2009 | 11:46 PM
lxman1's Avatar
lxman1
Site Moderator
Correct, the PCM sends out a voltage signal, the IAT is a variable resistor that changes with temp. As the air temp heats, the resistance goes down, thus raising the return voltage closer to the original voltage sent out to the IAT (Usually 5V on most vehicles). All the resistor does is reduce the voltage going back to the PCM enough that when the PCM converts the return voltage signal into a temp. number, it is a bit lower due to the added resistance. The PCM, then adds a little timing because it thinks the incoming air is cooler.
If you already have a tuner, you may get too much advance with the resistor/power wire because the tuner has already advanced the timing and leaned out the fuel mixture. By adding more timing from the power wire, you may have detonation issues which is not a good thing.
Old May 24, 2009 | 01:37 AM
Dodgeboy77's Avatar
Dodgeboy77
so it's probably like one of the higher horsepower programs on my programmer...
Old May 24, 2009 | 01:35 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I gave all the numbers on what a 2.2, 3.3 and a 4.7k resistor does as far as making the PCM think the air temps are different. If I am not mistaken, the 4.7k was a bout a 44* difference while the 3.3k was 22* and the 2.2k was 11* cooler. All these numbers came out of a SC3815
