Gears Suggestions
Old May 28, 2009 | 10:52 AM
TRXHemi's Avatar
TRXHemi
Default Gears Suggestions
Well, I recently got the go ahead from the wife to get some gears. I have the lowly 3.21 gears so I am looking forward to it.
I am considering the 4.10 and the 4.56 gear sets. I am currently running the stock 265/70-17 tires but will be upgrading to 285/70s in the near future.
Obviously everyone likes the 4.56s. The 4.10s should be plenty good as well I would imagine. Any issues installing the 4.56 gears?
Then there are the brands: Yukon, Motive, Richmond, etc. Comments good or bad?
Just looking for some comments and suggestion from those of you that have replaced the gears in your trucks. Thanks in advance...
Old May 28, 2009 | 01:34 PM
TRXHemi's Avatar
TRXHemi
WOW! No comments from the usually chatty bunch?
Old May 28, 2009 | 01:38 PM
OlDirtyJohn's Avatar
OlDirtyJohn
im gonna vote for 4.10s. im no expert by any means, but seems like if the largest tire you will be running is a 285, then 4.56 is kinda overkill. thats how it seems to me at least. im still in the same dilemma as you right now, minus the go ahead from the wife.
Old May 28, 2009 | 02:08 PM
TRXHemi's Avatar
TRXHemi
funny ^^^
I think I can get it done for about $300 in labor. Then the gears are about $250 or so. Would it be worth it to get the install kit?
Old May 28, 2009 | 03:02 PM
HammerZ71's Avatar
HammerZ71
Rule of Thumb #1: 4.10s for 33" tires or smaller. 4.56s for larger than 33s or heavy towing.
Rule of Thumb #2: Master Install Kit required if you have over 30k miles on your truck, Minor install if not...
Old May 28, 2009 | 03:04 PM
Cheeech's Avatar
Cheeech
^^^ Hammer said it all. Otherwise your gonna get into alot of personal preference.
Old May 28, 2009 | 03:16 PM
TRXHemi's Avatar
TRXHemi
Great Hammer - thanks.....4.10 is probably all I really need. I just don't want to pay for this and then say "I wish I had gotten 4.56s!" LOL
Truly, for what I use it for, 4.10s are plenty sufficient. It ain't no drag truck!
Old May 28, 2009 | 03:25 PM
Cheeech's Avatar
Cheeech
^^^^ Sounds like you found your gearset. Now just stick with that plan and get'r'done Don't forget about the front if you have 4wd.
Old May 28, 2009 | 03:55 PM
AF_HEMI's Avatar
AF_HEMI
3.21??!?! i thought the shortest gears the ram had were 3.55 if you didnt get the tow package. 3.21 comes in a lot of cars for economy reasons.
you should be good with 4.10 (unless you ever plan on lifting and bigger tires. 4.56 wouldnt hurt and you may as well so you dont kick yourself down the road)
Old May 28, 2009 | 04:57 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah as everyone has said, for what your wanting to do 4.10 would be the best option....could also check out the FAQ, good stuff in there about gears and whatnot
