Rear Differential
Old May 28, 2009 | 06:37 PM
DCullotta53's Avatar
DCullotta53
Default Rear Differential
So my rear differential is going out on my 03 ram 1500 4X4. its got the hemi with a 3.92 rear end. anyone have suggestions on where i can buy the parts to change it? and is it real difficult to change? Because the dealer wants $1500 to do it and that's more than i want to pay
Old May 28, 2009 | 09:06 PM
OlDirtyJohn's Avatar
OlDirtyJohn
how is it "going out"? i know that if you had the factory lsd, you have a very likely chance of it blowing up on you.
as far as doing it yourself.... prolly not. ring and pinion and all that stuff is a very specialized skill, and thats why no matter where you go for diff work, they will charge you
Old May 28, 2009 | 09:30 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
i'm sorry to say, this one is going to cost you. but 1500 for a single diff is quite high. for that much you can have someone do all new gearing with a detroit truc limited slip in a 4x4. should be half that if you have a 4x2, less without the trutrac.
Old May 28, 2009 | 09:54 PM
hemiyellow's Avatar
hemiyellow
DC Insider
if it's gonna be apart, might as well upgrade.....Auburn and Detroit both make excellent LSD componets....the auburn is gonna be about $100 less or so....you won't have the tools to do the gears yourself....need a special tool that goes in the axle tubes to back off the adjusters....also need to have a dial indicator so you can measure your ring gear backlash...having dummy bearings to get the correct thickness pinion gear shim is highly recommened (specially if re-gearing)
all in all....take it to a shop and have them do it....$1500 is rediculous just for the rear, should be around $700-800 or so....
