got the ram lifted finally
Old May 27, 2009 | 08:30 AM
grap660's Avatar
grap660
Default got the ram lifted finally
well this weekend i got the ram lifted 3 inches with the rough county lift i still havent posted pics because im still buying tires for it because dont know what size to go with im thinking 285 or 305 size tires and i also have 1 question do i have to regear my truck because of the lift and bigger tire or can i still keep the stock gears for a while
Old May 27, 2009 | 08:39 AM
Bigc9164's Avatar
Bigc9164
with 35s you really dont need to. but it is always a good idea to do it if you have an extra $800 laying around to buy them and install them. cant wait to see the pics!
Alpheus's Avatar
Alpheus
your mileage is gonna drop with bigger tires. 4:56 gears seem to put the lifted Rams right in the sweet spot for optimal low end power and mileage...
Old May 27, 2009 | 08:41 AM
BEAR's Avatar
BEAR
what gears do you have? 3.55's,3.92's what?
Old May 27, 2009 | 09:06 AM
grap660's Avatar
grap660
i got the stock 3.55 gears
Old May 27, 2009 | 10:34 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im running 305 width tires on mine now but bout to go to 325s this weekend.
Old May 27, 2009 | 08:38 PM
turbodieseldave's Avatar
turbodieseldave
my friend has 1500 with 6 + 3 lift and 37 inch tires we swapped to 4.56 and it runs like stock, before the gear swap it ran like a stock pinto. if you have the money to invest it is great to have, but to have someone do it is not cheap.
Old May 28, 2009 | 08:47 PM
TANKZ400's Avatar
TANKZ400
Is your truck a 2wd did you do a body or suspension.
Old May 28, 2009 | 09:59 PM
hemiyellow's Avatar
hemiyellow
DC Insider
the stock gears will work for awhile, but you'd deffinitly do yourself a favor by re-gearing....4.10 or higher would work great for you....if your gonna go to a 35 eventually, then 4.56 is the only way to go
Old May 28, 2009 | 10:05 PM
dazed01's Avatar
dazed01
i have 3.92's in mine and 35's. It runs 16-1700 rpms on the highway at 70ish and it's great
