fuel issues anyone????????????
Old 03-16-2005, 03:16 AM
pontiaco's Avatar
pontiaco
pontiaco is offline
Default fuel issues anyone????????????
hey guys I just got a '03 dualquad hemi and man this thing is sucking more gas than my '68 GTO 462 cubes-so far i've got 160 miles out of a full tank and my ceiling milliage thing it always starts reading 14.0s the it'll stick to 6.0s miles per gallon- it's this right? i do have a litttle heavy foot, but this past gas tank full i did take it easy just to see what mileage i'll get. I'm also a mechanic and have my own snapon scanner and there is no trouble codes and all the numbers are where they supost to be. I also just got front and back original oxigen sensor but the truck still sucking too much gas. also I have a remote start so every morning I make sure the engine warn befre I take off and yes my engine have the ticking noise!!!!!! thanks!!!!!!!!!!!!!
Old 03-16-2005, 01:38 PM
lucky13rme's Avatar
lucky13rme
lucky13rme is offline
Default RE: fuel issues anyone????????????
The remote start will eat up a lot of gas, especially if you have it running long. what size is your gas tank?
Old 03-16-2005, 01:50 PM
moparturd's Avatar
moparturd
moparturd is offline
What octane are you running? They recommend at least 89, but it will run on 87. I did notice a difference in mileage when I switched.
Old 03-16-2005, 02:09 PM
pontiaco's Avatar
pontiaco
pontiaco is offline
the truck has the 26 gal gas tank and right now i've been using bp 89 oct- the remote start it only runs for 10min-anymore sug????????????????????????
Old 03-16-2005, 02:22 PM
whitelight's Avatar
whitelight
whitelight is offline
Reprogram the CPU and let it relearn the fuel curves. If it STILL sucks too much gas, take it into the dealer and let them reflash it. 6 mpg is WAY WAY WAY too much.
Old 03-16-2005, 02:26 PM
|3|ackAc|D's Avatar
|3|ackAc|D
|3|ackAc|D is offline
per tank i get like 325-330 miles
Old 03-16-2005, 03:12 PM
Silver Eagle's Avatar
Silver Eagle
Silver Eagle is offline
My Manual says to use 87 oct and if you pull anything then use 89...but if you just use 89 your wasting your money.Don't forget to check your air pressure .I keep mine at 38 #'s. I have 17 inch tires.
Old 03-16-2005, 04:36 PM
magnethead's Avatar
magnethead
magnethead is offline
the roof meter isn't exactly accurate. Keep your tires at about 37-38 PSI (same for either rim size). And idling for 10 minutes is along time- the hemi warms up in about 2 minutes for us- even our 87 camaro warms up within 5 minutes.
Old 03-16-2005, 06:43 PM
moparturd's Avatar
moparturd
I just checked the 03 manual, and they recommend 89 octane for the Hemi (5.7L) for "optimal performance." Under the 87 octane section it says "for all engine except the 5.7L."
Old 03-16-2005, 08:32 PM
pontiaco's Avatar
pontiaco
pontiaco is offline
did I mention that I'm in chicago and here the temp's are right now in the 20's over night, so when I jump in the truck in the morning the gauge is bearly reaching the 1/4 mark!!!!!!!!!!!!
Quick Reply: fuel issues anyone????????????
