Replacing clutch pack clips on 9.25 LSD!
Thats exactly the usual death knell of these axles.
I just about got away with mine doing that.
My installer removed all the guts from my axel after the fine silvery powdery aluminium was found everywhere in my diff. Fluid....internals ...... and the magnet etc.
He then replaced all the bearings and seal and put in a DTT.
He saifd the caps were scored on mine but, theres still plenty of housing to suuport them.
So, that's how I've been running now for over 23,000 miles or so.
Al.
Al.
I have a question about the bearing cap though. What's with the bolt in the middle of it? The only diff I've ever torn into was a Ford 8.8 and it had no such thing. I gather they set preload. If so can I disturb one side without disturbing the other?
Ive never heard or seen anyone coming in here saying their LSD failed or gave issues because they pulled them. Thats not to say there isnt wear in them as described but no one I know has take extensive pics of thier LSD, pulled the clips, sealed the rear and driven for x amount of miles and pulled it back apart just to see.
Originally Posted by abarmy
I can personally confirm, that when I had run my LSD without any clips in the pockets for 20K+ miles, the pockets had worn and there were sharp edges to both the clutch pack tabs and the pockets themselves where they had been moving back and forth.
So it's been a while since anyone posted updates, was wondering how long I got until the clutch pack fails if I completely remove the clips, and also one of them are still in tact but it's pushed out and wearing down the casing bracket on the passenger side.. can i just hammer it back in flush and call that one good? The other it completely gone
Its already not working properly. The limited slip doesn't engage and it acts like an open differential..
I just bought it a few weeks ago and it appears like it's been a problem before I had it seeing how the pin is wearing into the carrier bracket.. Looks like I have to replace the clutch pack
