37" tire suggestions
Old Jun 17, 2009 | 07:11 AM
Muppet's Avatar
Muppet
Default 37" tire suggestions
Trying to find a good AT 37" tire to fit on my stock rims, Tire rack had a few but do you guys know of any other good places that would have what I am looking for?
Would like something that will last a while.
Old Jun 17, 2009 | 08:13 AM
HammerZ71's Avatar
HammerZ71
You own a 2500?
Old Jun 17, 2009 | 08:29 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What size would your stock rims be? Ive got 36'' ATs but my rims are bigger than yours.
Old Jun 17, 2009 | 11:14 AM
Muppet's Avatar
Muppet
Sorry, 04 1500. 17 inch rims
Old Jun 17, 2009 | 11:18 AM
HammerZ71's Avatar
HammerZ71
You are going to run into issues. Not even discussing the problems that tires over 35" cause to CV axles (assuming your a 4x4) and other front end components, the tire width is going to cause a problem on your stock wheels without wheel spacers (further adding to the strain the 37s will put on the front end) or a wheel with a sufficient offset and backspacing (which the stockers do NOT have). Normal width on a tire that size is gonna be 12.5" or more...
Old Jun 17, 2009 | 12:45 PM
dirtydog's Avatar
dirtydog
Moderate User
^^^^ Not to mention they just won't fit unless you have atleast a 3" body and a leveling kit to boot. Plus 35's look too crammed in stock fenders with a level kit. 37's wouldn't fit and would look ridiculous.
Like said, you need a descent lift to run 37's.
Old Jun 17, 2009 | 12:54 PM
Muppet's Avatar
Muppet
3" body and level kit are in the plans, the kit is on it's way but still need to order the body kit. Won't be changing the tires out for a bit, If they won't fit on the stock rims I guess I have to do some rim shopping, and gear shopping.
What is the total average cost of 4:56 gears front and rear + install? I assume a dealer can install them.
Old Jun 17, 2009 | 01:12 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I just got quoted 400-450 to swap my gears and LSD
Old Jun 17, 2009 | 02:30 PM
dirtydog's Avatar
dirtydog
Moderate User
Not for front and rear diff you didn't!
Dealer will charge you book rate. Prob gonna be around $1200 just for labor not including any parts.
Old Jun 17, 2009 | 02:50 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, sry, just for the rear. I have a 2wd.
