Changing Differential Fluid
Old Jun 20, 2009 | 12:14 AM
shadow11's Avatar
shadow11
Default Changing Differential Fluid
I decided to change my differential fluid tomorrow cause my truck is about to hit 90kmi and I dont know if the previous owner ever did or when the last time was. What brand of fluid are yall running (mobile 1, amsoil, ect,ect) and I need to get 75w-90 fluid right? Also how much fluid should I get? Its an 03 2wd with 3.55 gears open diff.
Thanks
Old Jun 20, 2009 | 03:15 AM
BEAR's Avatar
BEAR
Thanks
I use Royal Purple in everything on my truck. A little over 4 pints is how much you need. I think if you do much towing they recommend you use 75-140 in the rear, if not I think the 90 will be fine.
Old Jun 20, 2009 | 05:17 AM
abarmby's Avatar
abarmby
They recomend 70w 140 at all times in the rears I believe.
The 70w 90 is if you cant find the 140 cheap enough and is a cost cutting measure.
Al.
Old Jun 20, 2009 | 08:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yep, 75-140 in mine too.
Old Jun 20, 2009 | 09:08 AM
MikeHTally's Avatar
MikeHTally
75w-140 is what the book says. 4.9 pts I used Mobil 1.
Old Jun 20, 2009 | 09:44 AM
PyRoHAvoC's Avatar
PyRoHAvoC
how hard is it to do this ... sounds like something i need to get done as well ...
Old Jun 20, 2009 | 12:45 PM
BEAR's Avatar
BEAR
Not hard at all. You can do it in your driveway in about 30 mins. Just remember to clean the magnet off and do a visual inspection while you got the cover off.
Old Jun 20, 2009 | 01:44 PM
shadow11's Avatar
shadow11
So I should get 75w-140 cause I thought I only needed 75w-90? I tow a little but not very often. Remember I dont have the lsd.
Old Jun 20, 2009 | 07:39 PM
nim81's Avatar
nim81
my owners manual says 75w-90. 2002 with the 9.25 corporate rear axle
Old Jun 20, 2009 | 10:12 PM
shadow11's Avatar
shadow11
I just finished changing the diff oil a few hours ago. I went ahead and got Royal Purple in 75w-140. Thanks for all yalls help!
