Diff Covers/Trans Pan/Fluid
Old Jun 20, 2009 | 12:26 PM
JoshGotaHemi's Avatar
JoshGotaHemi
Default Diff Covers/Trans Pan/Fluid
Hey guys,
Just hit 50k on the truck, ready for some maintenance. I was thinking that while I have the rear diff cover off, and the trans pan open, that I might replace them with something with cooling fins and more capacity. Do any of you guys have a cover/pan that you're fond of? Is there a diff cover for the front diff(1500 w/IFS), or is the front crossmember too close?
I'm going to start using Royal Purple, so I need to order some of that soon. Do any of you use the Synthetic Royal Purple in the trans? Is it ok for me to mix synthetic with non-synthetic, since I know all the fluid won't come out of the torque converter/trans? How much fluid will I need in the trans during the service? Thanks in advance!!
Josh
Old Jun 20, 2009 | 12:42 PM
BEAR's Avatar
BEAR
Originally Posted by JoshGotaHemi
Hey guys,
Josh
I use RP in everything on my truck. The Syn/Non Syn mix will be ok. The only way to get it all out is to do a flush. If I remember right it takes around 7-8 quarts to do a drain and refill and filter change. Remember there are 2 filters on the tranny to be changed.
Old Jun 20, 2009 | 12:48 PM
JoshGotaHemi
I think I did know that, I'll go to the dealer Monday to get the filters and friction modifier. One is the normal flat type filter and the other is a screw on, correct?
Old Jun 20, 2009 | 01:00 PM
BEAR's Avatar
BEAR
Thats right and if your using RP in your diffs also then you don't need the FM. Your decision but the filters would probably be cheaper from a parts house such as O'Rielys or Advance.
Old Jun 20, 2009 | 01:35 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And if you take loose the trans line at the cooler and then crank the truck for a bit, it will pump the old oil out and allow you to replace it with fresh oil. Thats how I changed all my old oil out. I also use RP in the trans. It took 17 qrts and cost about $10 a qrt. When replacing that flat filter, I had to go to Autozone and buy the little hook tools so I could pull that old Oring out. I tried things from around the house including a clothes hanger but the metal wasnt hard enough. I think I paid $10 for them (pack of 4)
Old Jun 20, 2009 | 01:39 PM
dirtydog's Avatar
dirtydog
Moderate User
^^ Mechanics pick set. I use mine ALL THE TIME!!! To clean out my bowl too.....,aaahahahahaha
Old Jun 20, 2009 | 04:04 PM
toxdoc's Avatar
toxdoc
Hey guys,
Josh
Like many others on DF - I use Royal Purple in the trans. & diff. fluids even Royal Purple Ice in the radiator - Mobil 1 & Mobil 1 filter for oil. For pans I use the PML polished pans and have had good service with them. There are several others that are nice as well***
Old Jun 20, 2009 | 06:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
How does that Ice in the rad work for you? Is it worth it and was there any noticable change in the temp gauge?
