Radio guys
Old Jun 21, 2009 | 01:48 AM
MontanaRAM's Avatar
MontanaRAM
Default Radio guys
where are y'all mounting your CB's? the only place i can really think of is the dash, maybe under the steering wheel.
Old Jun 21, 2009 | 02:24 AM
JoeHemi's Avatar
JoeHemi
Just threw it together real quick. Using velcro in that slot to keep everything intact and not flying out. You'll need to cut a big hole or completely hollow out the back of that slot in order for the CB to sit in there good because of the antenna cable.
Old Jun 21, 2009 | 03:14 AM
Bluesmanjesse's Avatar
Bluesmanjesse
You probably don't want it under the steering wheel,I have a trailer brake control there and I'm always hitting my knee on it.
Old Jun 21, 2009 | 06:43 AM
ramhunter9's Avatar
ramhunter9
mine is in the same spot as joes
Old Jun 22, 2009 | 12:39 AM
soundwavesram's Avatar
soundwavesram
I had one in my truck but took it out due to lack of use.
Here are some pics of the mount I custom built for it. It mounts to the center seat mounting bolts.
Old Jun 22, 2009 | 01:05 AM
MontanaRAM's Avatar
MontanaRAM
hmm, i like this idea. the only problem i see is that my seat is pretty close to the cupholder, so i dunno if i could fit one without having to adjust my seat back farther, guess it's a small price to pay though. do you have pictures of the bracket you made?
Old Jun 22, 2009 | 01:37 AM
soundwavesram
Not right now, I can look through my tool box to see if I have the mount still, and grab some pics for you.... Heres the link that I based the mount off of though... http://www.genosgarage.com/prodinfo....CB_MOUNT_0305N
But for mine, I put the narrow part closer to the driver side, and I just welded the mount that came with the radio to the peice that I made.
Old Jun 22, 2009 | 11:12 AM
MontanaRAM's Avatar
MontanaRAM
thanks, looks like i'll need to get me some tinmetal down at the home depot later.
Old Jun 22, 2009 | 10:45 PM
02dodgeram5.9's Avatar
02dodgeram5.9
Here is how i mounted mine...WORKS PRETTY SLICK..i mounted it to the cup holder and so i still have full use of the cup holder and it still holds it up..but here is another option...good luck
Old Jun 23, 2009 | 03:29 AM
09W3500's Avatar
09W3500
I like the looks of that mount on the link you gave, soundwavesram. I wonder of it interferes with the cup holder?
I like my Ram, but they sure didn't make it easy to mount accessories (like radios & brake controller).
I just got off work & checked... I keep my seat in the rearmost position so there ought to be plenty of room. Thanks again for the tip!
