Couple of questions???
Old Jun 21, 2009 | 06:37 PM
JonM2007's Avatar
JonM2007
Default Couple of questions???
I have a 2004 Dodge Ram 1500 Quad Cab SLT. The rear passenger side turn signal quit working and I know it not the bulb or the taillight housing. So I think that it might be a wiring issue. I also know it not a fuse. Has anyone heard anything about this or is this a popular problem on these trucks. Also my other problem is that when I start the truck and it is in park it idles up and down. No CEL or anything like that. Does anyone have any suggestions to what might be wrong??
Old Jun 21, 2009 | 08:17 PM
BEAR's Avatar
BEAR
I've heard alot on here about a board that goes bad that controls the tail lights. I don't know alot about it cuz I ain't never had it happen to me but maybe someone else will chime in on that. From what I understand they aren't very expensive to replace. As far as the idle problem, when was the last time you cleaned the TB? And BTW Welcome to the DF!
Old Jun 21, 2009 | 09:13 PM
hemidel's Avatar
hemidel
I 2nd the throttle body cleaning if you havent done it. As for the lighting issue, i had the same issue with my passenger side rear tailight. I never really figured out the problem, but i had to replace a bulb back there and when I put the taillight back on, it was working. It had to do something with the wiring or plugs back there. Anyways, i was intaking some water in that tailight so i replaced it and it came with a new backing where you screw the bulbs in. Never had a problem again. Just check your plug in connections.
