3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
This morning on my way to work, everything was fine. I just left on my first break and rolled my driver's window down. I noticed a creaking noise as it went down and up. It's a black 04 QC 4x4 with 25,000 miles and it has been pretty hot lately...don't know if heat has anything to do with it. Anyone have this problem before? Any ideas?
I'm gonna say the metal frame changes form a little when heated inside that door panel which puts pressure on everything and that's where you are getting your noise from. It's a metal track that has rollers inside the guides so they can make noise if they are binding. maybe pull the panel off and grease it up a bit.
