Hey guys, Couple of things if you don't mind
If fluid isn't circulating wouldn't that prevent the hot coolant from getting to the radiator and evaporating in the first place.
I live in Texas btw, and this started happening when we started getting days like 105, 103, 102. lol
Holding pressure is a relative term, could be 2lbs could be 20lbs.
1) I'm 99% sure the problem is not the temp gauge (sorry cowchick). I've had this problem on other vehicles. Your friend is 100% correct with the thermostat diagnosis. Thats exactly what happens... fluid doesnt circulate, isolating the resovoir and evaporating the fluid out of the radiator. Changing the t-stat should definently fix it. If its still running super hot on occasion, change out the temp sender (cheap $10 part), and if that doesnt fix it, perhaps the water pump, but im really stretchin it here...it should've been fixed with the t-stat.
--Cow-Chick--
Alright well I drove it around a bit in the 105 degree heat and it was running a little hot still...Not all the way topped out at hot, but about 3/4 of the way up and it usually sits at about the middle.
I was thinking maybe I didn't put enough coolant in last night after I replaced the thermostat, but it would pull it from the reservoir tank if that was the problem, wouldn't it? Cuz that tank is still full.
I'll try replacing the cap later, but I have to get to work and don't have time to do it right now...
I'm thinking it might be a head gasket after what that one guy said here. I don't notice any smoke necessarily when I start it up, but I have noticed a smell that smelled like coolant sometimes.
How much would it be to replace a head gasket if it is indeed blown?
Well honestly I could do it at my friends house w his dad and him I think. His dad built a 69 camaro and a 68 from nothing, so I know he can do it I just didn't know how much parts would cost and what not
A bad radiator cap can allow pressurized coolant to escape from the radiator but not allow it to draw any back in when it cools down.
If it boiled it out, your reservoir would have overflowed and blew coolant all over the engine bay. It won't just evaporate from the cooling system.
Sounds like you have an air pocket now and perhaps a blown head gasket allowing coolant to be burned in a cylinder.
The radiator may be partially clogged as well.
