Transmissions, Torque Converters and Rear Gearing - How to Improve RWHP
Old Jun 29, 2009 | 05:12 PM
  #31
dirtydog's Avatar
dirtydog
Moderate User
I'm sure an aluminum driveshaft may help with a few horsies, but otherwise i would start back at the beginning. E-fan, E-waterpump, underdrive pullies.
Old Jun 29, 2009 | 06:07 PM
  #32
truckin151's Avatar
truckin151
What about a shift kit or a reprogram kit for the trans? Other than improving the shifts would it help get a little more power to the wheels?
Old Jun 29, 2009 | 06:10 PM
  #33
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
the only way that a trans adjustment would make more power, is if you were shifting before your powerband peaked...which isnt the case, so while a more positive shift will make the truck quicker, it wont actually add any power to my knowledge.
Old Jun 29, 2009 | 06:27 PM
  #34
truckin151's Avatar
truckin151
Alright cool looks like I have everything to get the trans running as good as it can get then.
Old Jun 29, 2009 | 06:56 PM
  #35
dirtydog's Avatar
dirtydog
Moderate User
I would get a deep tranny pan that has cooling fins on it. That paired with the cooler you will do and you'll get consistant predictable shifts.
Old Jun 29, 2009 | 06:59 PM
  #36
SilverBullet08's Avatar
SilverBullet08
http://sharadon.com/sdparts.htm
sharadon trans...
Old Jun 29, 2009 | 07:02 PM
  #37
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
the TC made a hell of a difference on the mirada, especially when i went to the 4000. now that we have the 06, when we rebuild the trans in the 94, i hope to go to a bigger stall.
Old Jun 29, 2009 | 10:01 PM
  #38
cramerica's Avatar
cramerica
**ugh...serious double post issues tonite**
Old Jun 29, 2009 | 10:02 PM
  #39
cramerica's Avatar
cramerica
Replace your engine, trans and axle fluids with performance (Royal Purple, AMSOil, etc) before you go buying an aluminum driveshaft.
As long as the transmission clutch packs are not slipping in gear, a shift kit will not increase power to the wheels. The truck will perform better, but for other reasons.
Lighten the beast up...if you want to. It's not easy in Dodge trucks; lots of iron...
Old Jun 29, 2009 | 10:23 PM
  #40
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
my 06 looks to have an aluminum driveshaft now...if its steel, its the cleanest steel DS ive ever seen...
