Creaking noise at take off....
Old Jul 4, 2009 | 08:52 AM
sabedra211's Avatar
sabedra211
Default Creaking noise at take off....
Hello if im at a stop and i step on it my truck will make this metal creaking noise or if im rolling at 10 mph and stomp on it, it will also make a creak . what could it be? I cant tell where its coming from? Could a leaking rear pinion seal cause this noise? thanks! its an 04 QCSB with 115,xxx miles.
Old Jul 4, 2009 | 10:16 AM
jonnymagnum's Avatar
jonnymagnum
could be your u-joints. if not, I would be looking in the rearend.
Old Jul 4, 2009 | 10:41 AM
02Regcab's Avatar
02Regcab
Is it more of a creaking noise or a chirp?
Chirping is most likely U-Joints if its only audible at low speeds
Old Jul 4, 2009 | 04:31 PM
sabedra211's Avatar
sabedra211
i think its more of a creaking noise. like the noise of opening an old car door..
Old Jul 6, 2009 | 02:46 PM
fish n chicks's Avatar
fish n chicks
I might have the same issue as you do and have traced it back to my rear suspension. Haven't identified if it's the shocks or the leaf springs but will most likely upgrade both cause I tow a boat.
Old Jan 1, 2010 | 10:53 PM
OhioHomesteader's Avatar
OhioHomesteader
Lube all the sliding surfaces on and between the rear springs. If you back the rear of the truck into the lake use white Lubriplate lower unit grease (for outboard motors). It is fairly waterproof and will stop the squeaks.
Old Jan 1, 2010 | 11:11 PM
stuntpilot's Avatar
stuntpilot
If it makes a metalic chirping or clanging noise when you change between first and reverse then it's your UJ's
Old Jan 1, 2010 | 11:14 PM
CarGuyOhio's Avatar
CarGuyOhio
That could be a number of things. Really need more info like an area it seems to be coming from, if it is worse when cold....
Old Jan 1, 2010 | 11:45 PM
mbaseball3's Avatar
mbaseball3
I had probably the same noise on my ram as you do back when I upgraded to a rough country 3 inch spindle lift. with new u bolts around the leaf springs and the new block in place. never checked for torque requirements but they gotta be tight. even after impact wrench I had to use a galvanized chain link pole; bout 5 feet long, on handle of socket wrench to give it a snug fit lol. torque on it now is probably massive with the leverage applied but that same noise you speak of, went bye bye.
Old Jan 2, 2010 | 06:34 PM
sabedra211's Avatar
sabedra211
Ya I think its my U-joints . When its real cold outside when i shift from Park to reverse i hear a creak noise and then again from reverse to Drive it does it again. Would greasing them up save them or should i just get them replaced? thanks
