speaker help 03 ram 1500 non infinity
Old Jul 5, 2009 | 09:34 AM
bulletperformance's Avatar
bulletperformance
Default speaker help 03 ram 1500 non infinity
so i thought i had a bad speaker on the drivers side rear door and so i went out and spent good money on some new speakers i installed them and still no sound from that side anyone got any ideas?
Old Jul 5, 2009 | 09:56 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Easiest/fastest thing I would think of it a new aftermarket HU.
Old Jul 5, 2009 | 11:54 AM
kicker417's Avatar
kicker417
check for the wiring make sure its not cut or anything or change the wires around.
Old Jul 5, 2009 | 12:57 PM
bulletperformance
i checked the wires to the factory hu and there is no pinching or cut wires and i also bout the plug kit so there i wont have to flip the wires around it plugs into the stock harness and then into the speaker
Old Jul 5, 2009 | 03:19 PM
chambers's Avatar
chambers
Could be a bad channel of your head unit, is it OEM? You could get another one of the classifieds on a dodge site, ebay, or craigslist for cheap. I am assuming you have checked the obvious things like balance and fade on the unit. I would say replace the head unit either w/ OEM or aftermarket whichever you like.
Old Jul 6, 2009 | 02:17 PM
tuned93's Avatar
tuned93
i love it when things break on my truck... that means i have a GOOD reason to get something new. my suggestion is to just get an aftermarket head unit. problem solved!
Old Jul 6, 2009 | 04:54 PM
matty_p's Avatar
matty_p
A guy I work with had a similar problem. It affected his D/S rear speaker and window. Took it to the dealer and they said that the harness that plugs throughthte B-pillar can be too short in some trucks. They wanted like $300 to fix it. He went home and pulled it out and lengthened the wires and has had no other problems with it.
Old Jul 7, 2009 | 12:35 AM
tuned93's Avatar
tuned93
you gotta be REALLY careful when doing electrical work. but as long as you make good connections, do it safe and work on one wire at a time... you should be fine.
