Major Problem? Maybe
Old Jul 10, 2009 | 10:42 PM
mopardad68's Avatar
mopardad68
i might be off base but have you thought of continuity test on blower motor or from the plug with a wiring scamattic[sp] or am i out in left center again?
Old Jul 10, 2009 | 10:47 PM
reefguy89's Avatar
reefguy89
y would i do that? I know the wire goes to the blower
Old Jul 10, 2009 | 11:01 PM
mopardad68's Avatar
mopardad68
wouldnt u check continuity to see if there was a prob with blower motor or would u check voltage drop, its been a while since i messed with electrical, just thought if u could eliminate the bad connection[ incomplete ciricuit youd have better ideaa where prob was, like i said been a while and the test im thinking of i might have missed on terminology, or have i completely confused ya
Old Jul 10, 2009 | 11:05 PM
reefguy89's Avatar
reefguy89
the motor will run i put on an amp meter but it is only drawing .20 amps
Old Jul 10, 2009 | 11:08 PM
mopardad68's Avatar
mopardad68
it was only guess, was i remembering the electrical stuff from high school correctly on looking for a faulty ground or incompltete circuit or was i all f-ed up on my thinking, shouldve paid more attentioin twenty+ years ago i reckon
Old Jul 11, 2009 | 01:10 AM
lxman1's Avatar
lxman1
Site Moderator
It appears that the bad connection was at the connector. Either the plug itself or where the wires are crimped into the connectors.
Old Jul 11, 2009 | 07:51 PM
03dodge's Avatar
03dodge
I had the same problems with my 03Ram. You can buy the ignition box from the dealership for around $85 and it comes with all the wires. I just replaced the wires that were in bad shape. The blower motor on my truck was the plug. I was told by the dealership you can't buy that plug. The fix took less than an hour not a very big job at all. No problems since thank god.
Old Jul 11, 2009 | 10:26 PM
reefguy89's Avatar
reefguy89
i order the switch from advance auto today for 23.99. I am goin on monday to a coulpe of junk yards to find the connector. What years would i be able to try to pull it from besides an 03 or does it have to be specified by motor size?
Old Jul 15, 2009 | 04:48 PM
reefguy89's Avatar
reefguy89
ok got some good new i found the connector that i need. I got the wire harness that goes under the dash near the column. It has like 6 connectors on it. I got it for $25. So my question is what is the best way to connect the new plug in? I was just goin to cut them and use butt connectors to splice them together. Then wrap them in shrink wrap. Is that good enough?
