Leveling Kit questions
Old Jul 16, 2009 | 07:17 AM
explorer9950's Avatar
explorer9950
http://www.autotrucktoys.com/ram/Day...8453C4675.aspx
There is the 2.5 spacer, it will fit your model, you will need new shocks, but other than that you will be good to go..
Old Jul 16, 2009 | 07:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Here is the link for the 2.5s for $80
http://www.avsporttruck.com/secure/i...roducts_id=109
And 06DodgeRam2500 is right. CST does make a 3'' and thats how they get thier hieght. Their 3'' spacers are either 129 or 159, I forget which. But those are what I will be ordering soon so change out the ones I have now.
Old Jul 16, 2009 | 08:19 AM
dynamos2000's Avatar
dynamos2000
Originally Posted by ramhunter1
1.5 is all you are going to get with a 2wd sorry. 4ed trucks sit higher stock than the 2wd.
Friend is installing the 2.5 daystar lift on my 2wd and replacing with 2500 series bilstein shocks - friday barring no issues
Old Jul 17, 2009 | 02:43 AM
Dskaggs20's Avatar
Dskaggs20
Keep me posted on how that install goes.........thank you all very much for the info.....im thinking about going with the 2" from bobs.....did the 2" get the truck level or was there still some rake, im wanting to acheive either alittle taller or just level no rake?....
the shocks im looking at going with are the pro comp es3000 any negatives on that model i have found that at 40$ a peice to be the cheapest and best performance for the buck?
Old Jul 17, 2009 | 10:01 AM
TRXHemi's Avatar
TRXHemi
I got the Fat Bob's kit with the Fabtech shocks. I actually got about 3.5" on the front.
My back and front are both the same now.
Before:
After:
Old Jul 17, 2009 | 10:37 AM
dynamos2000
Hopin to get her back in a few hours, will let you know. What I've read here is to expect a slightly higher front end - which is good for me since I wanna add a bar to the front and it will lower it a touch I'm sure
Old Jul 18, 2009 | 09:42 AM
Dskaggs20's Avatar
Dskaggs20
can you post some before and afters for me?
Old Jul 18, 2009 | 01:54 PM
dynamos2000
Daystar 2.5 and bilstein 2500 series shocks - rides better and looks better, will take better pictures when I have time.
Highly recommended!
Old Jul 18, 2009 | 03:35 PM
Dskaggs20's Avatar
Dskaggs20
What size tire you gonna go with?
Also have you had any upper control arm contact with the spring?
did you just order the dodge ram 2500 2wd front shocks or 4wd?
Looks great im excited to get mine done!!!
Old Jul 18, 2009 | 04:26 PM
dynamos2000
I've only got 12,000 on the original tires so no big hurry right now. 2wd
