What parts do I need?
Old Jul 17, 2009 | 12:05 PM
glenn.d.smith's Avatar
glenn.d.smith
Default What parts do I need?
Ok so I still have the tick and I accept that no combination of oil/filter/mechanic in a bottle is gonna help my situation. With that out of the way I was thinkin bout taking the top pans off and having a look at the valve springs/push rods/rocker arms etc... I'm pretty sure that I can do that part ok but what are some things I need to look for or measurements I should take? I understand that the consensus around DF is that the valve stem guides need to be increased - is this possible to do without removing the heads? I read elsewhere that the pushrods may be a hair too short as well. Is it possible to remove the push rods without removing the heads?
Thanks
Old Jul 17, 2009 | 12:11 PM
rebel61021's Avatar
rebel61021
all Hemi's tick not much there is to do about it. That is what I thought.
Old Jul 17, 2009 | 12:19 PM
regert's Avatar
regert
If you are able to fix the tick PLEASE PLEASE fill us in thanks
Old Jul 17, 2009 | 03:26 PM
glenn.d.smith
I think if I could fix the tic I'd be very rich indeed.
Its just that I've read alot on here about ways that some have had success and I'd like to try myself - I figure if I'm gonna have a look I could probably replace some suspect parts while I'm in there.
Old Jul 17, 2009 | 04:01 PM
rtmtrrdr's Avatar
rtmtrrdr
If it ain't broke, don't fix it
Old Jul 17, 2009 | 11:57 PM
lxman1's Avatar
lxman1
Site Moderator
Valve guides are pressed into the heads and the heads must be removed and disassembled to replace them. Nothing you can do on the truck. You would think that after 6 years, they would have fixed this problem by now.
Old Jul 18, 2009 | 12:13 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There was a thread over on DT where the Chrystler engineers issued a case number on the issue and found in some cases the valve guides had too much play and some exh valves needed to be replaced. Some people had used slightly longer push rods and also solved thier issues. But overall, this is something that guys have resolved.
Old Jul 18, 2009 | 07:49 PM
glenn.d.smith
Thanks for the replies guys. I guess as long as the truck doesen't develop any major problems I should just suck it up and put the hammer down - maybe crank the radio too Just seems odd for such an awesome truck to sound like an old beater. Anyone know if the 09's are developing the same noise?
